Old 12th March 2007, 05:16 AM   #1
Send a message via AIM to Phergus_25 Send a message via Yahoo to Phergus_25
Default Sub for Full range horns
I recently made a pair of Austin A126s, and I have yet to do measurments, but in thinking about adding a sub of some sort. I would like to use the speakers natural roll off and only crossover the sub. And suggestions as to what works best with fullranges?
-greg
Old 13th March 2007, 08:35 PM   #2
zobsky is offline zobsky  India
zobsky's Avatar
Default Re: Sub for Full range horns
-greg
a horn sub works well for back loaded full-ranges.
"Any fool can know. The point is to understand" - Albert Einstein
Old 13th March 2007, 09:48 PM   #3
Any good ones around. Im having a hard time getting through the threads to find waht is decided upon to be good.
-greg
Old 15th March 2007, 02:28 PM   #4
I was directed to the Autohorn, but im afraid that it might not go low enough. Any othr suggeestions or experiance with the auto horn?
-greg
Old 15th March 2007, 03:13 PM   #5
Zobsky,
Which Horn Subs are you using and which do you recommend?
Ray
Old 15th March 2007, 03:38 PM   #6
zobsky's Avatar
For what its worth, I use an autotuba currently with a set of line arrays. Good to around 30 Hz. I used to use (and still have) a 12" ported adire shiva tuned to 17Hz but that simply isn't efficient enough for an efficient set of speakers. It also doesn't seem to match "tonally" . I tried the same shiva in a sealed enclosuree but just didn't like the sound.
YMMV
Old 15th March 2007, 10:03 PM   #7
RobWells's Avatar
The 'usual suspects' for horn subs are the labhorns or the Bill Fitzmaurice stuff (tubas).
You need to work out if you have enough space for horn subs as they're not small.
If space is an issue maybe try the punishers down to 40hz and use something more conventional for the bottom octaves.
Rob.
Old 16th March 2007, 06:53 AM   #8
frugal-phile(tm)
planet10's Avatar
We have been building push-push Extremis subs... 1 per side is nicest. The extended range makes them easier to integrate... with room gain, the vented enclosure (pushing aperiodic) gets them into the mid 20s. 2 fit in a 16-17" cube (but we use lots of shapes)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th March 2007, 07:31 AM   #9
Dave,
I considered the apex Jr. push-push sub several weeks ago but it was too small for my application because they needed to do double duty as sofa end tables in my small HT (13'x14' room). I had all but decided to build a pair of single driver 12" or 15" sealed subs probably using the Dayton RS series drivers when I saw your new Extremis based design. Tell me about your new design and its suitability for my application.
Ray
Old 16th March 2007, 07:58 AM   #10
frugal-phile(tm)
planet10's Avatar
Here's a start ...
http://homepage.mac.com/tlinespeaker...ube-woofer.pdf
http://homepage.mac.com/tlinespeaker...mis-woofer.pdf
Full size 142Hz round tractrix horns JLH Swap Meet 19 16th May 2010 11:16 PM
DIY 4way full frontloaded Hornsystem with MDF tractrix horns angeloitacare Multi-Way 21 21st February 2010 12:33 PM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
i need a full range for max 50w sexya Full Range 0 26th August 2007 03:58 PM
Page generated in 0.09595 seconds (80.24% PHP - 19.76% MySQL) with 11 queries
