Old 21st September 2007, 09:00 PM   #601
Hi ,
Built my other trapped horn today.now I have STEReO sub
here is the curve from Hornresp.
Its the best I could do with this driver (Perless Resolution 10) in 20 tryouts...?
I wonder if someone with experience of building these type of horn could tell me if it looks OK?
I sounds ok ..the peaks above 100hz is not disturbing and for the moment I have 2 conical pipes with a 6db lp passive filter at 50hz and for a room 60m2, I only use 1W and 10W at the peak.
I use these with Open baffles at the moment.
the sound is WERY loud and very clean and deep
VERY physical bass with volume above live level.
very open and Airy sounds almost as good to Heavy orck and ,Bjork as with jazz and acoustic music.
I used to have Jensen "Onken" 200litres box with 15" and thats was the best bass i had until now.
These are as good as the great klipsh cornerhorn and other big horn I have heard.
Its easy to become a bassfreak and overlevel these boxes..
Old 21st September 2007, 11:01 PM   #602
Here is the "hornresp" curve
Old 22nd September 2007, 12:11 AM   #603
zobsky is offline zobsky  India
zobsky's Avatar
That graph is unreadable
"Any fool can know. The point is to understand" - Albert Einstein
Old 22nd September 2007, 07:04 AM   #604
Naudio is offline Naudio  United Kingdom
it is roughly flat from 30hz-100hz as far as i can make out
i would like to learn how to design horns is there a guide available on how to use the horn response program because all i see is a load of letter combinations that make little sense. basically it looks baffling at first but is probably simple when you learn it
thanks
Old 22nd September 2007, 02:28 PM   #605
zobsky's Avatar
thanks
check the wiki on this website
Old 23rd September 2007, 03:49 PM   #606
thanks great looking guide carnt wait to get crackng
has anyone heard about those fan sub woofers? i think they only work as IF but in a horn u could blow a house down
Old 23rd September 2007, 06:57 PM   #607
Taterworks's Avatar
Take a look at the articles on the Danley Sound Labs web site and read the one about the SBG - the Sonic Boom generator (an Intersonics project for a government contract). It uses six 5 HP fans and a servomotor-controlled rotary valve to generate its acoustic output. This is off topic, but it deals with what you suggested - the fan subwoofer in a horn-type thing.
If it works, but you don't know why it works, then you haven't done any engineering.
Taterworks Audio (nothing for sale)
Old 24th September 2007, 02:13 PM   #608
Buzzy is offline Buzzy  Singapore
Wow the thread has become so Big ! After reading a few posts of those who have built this sub i am very interested in building this sub.
May i know which S1, S2, S3 ,S4 and the con ? It would really help if someone could point where or draw on the pic below to show where these lengths are in a tapped horn.
Old 24th September 2007, 02:56 PM   #609
http://img155.imagevenue.com/img.php...122_1037lo.JPG
Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 24th September 2007, 05:35 PM   #610
1. In the above pic is S3=L34 ?
2. Where is S4 suppose to be ?
3. S2 is the length from the back of the cone to the opening right ?
4. The blue line which is L23 is it suppose to be parallel to something and the how is the angle of the part indicated by pink arrow determined ?
Page generated in 0.13431 seconds (72.96% PHP - 27.04% MySQL) with 11 queries
