Collaborative Tapped horn project
Old 15th March 2013, 01:29 PM   #3951
kees52 is offline kees52  Netherlands
Originally Posted by David McBean View Post
Hi kees,
It is not necessary to use the exported schematic diagram data to construct a bass horn. Simply ensure that the internal cross-sectional areas and axial lengths match those of the Hornresp input parameters.
For your given text file example, this means that:
S1 = 100
S2 = 200
S3 = 800
S4 = 959
L12 =50
L23 = 430
L34 = 50
You will need to use you own judgement when determining the effective lengths of acoustic paths around bends.
Kind regards,
David
Hi David
When use the output I can make nice bends? see the picture post 3848 as example, not the real one afcourse.
If I do S3 800 and S4 959 then it go like on the picture, I need to get S1 to S4 so that it is pure conical otherwise I have a bend in the middle of the speaker, this is the last part I do need to now, the rest I have it.
I think S1 200 S2 800 S3 800 and S4 so That it do not bend, maybe I need to now a rule here from the experienced here. I see that I can make the mouth smaller or the S3 taller to get it a straight line to the mouth.
Sorry about my green ears.
thanks
kees
Old 15th March 2013, 01:35 PM   #3952
R.I.P.
Why does the final section need to be conical?
What's wrong with parabolic for all sections?
regards Andrew T.
Old 15th March 2013, 04:20 PM   #3953
Hi Andrew
I don,t get how to set it like you all do, one straight line from mouth to throat I did mean all parabolic, I show what I want to see in the picture below.
I have now uses only measurement of S1 S2 S3 S4 like David say, the picture in the post before S3 and S4 did bend, and how it looks now I do need for easy workout the box.
picture horn, and response of the infinity 1260W etc like it is now with straight angle and not as last post this is what I want but what is the best way, that is what I did mean so Andrew there is nothing wrong with parabolic but I need no bend in the middle of the speaker...
What I also not get 100 % is how I do fill in extra volume in hornresp for braces and such, like the driver volume, do I make the S3 and S4 bigger ? for example if bracing is 10 liters in the long part I do make S3 10 liter bigger, this are the last parts, If I now them then I have remove my greenery behindthe ears I hope.
Thanks all for the help, and some input about the design I do like also and maybe some extra info..
Old 16th March 2013, 12:11 PM   #3954
David McBean is offline David McBean  Australia
Hi kees,
S3 is a cross-sectional area, not a volume.
To remain consistent with the simulated design, the value of S3 should not be changed.
Kind regards,
David
www.hornresp.net
Old 16th March 2013, 12:59 PM   #3955
Hi David
Yes I do now but how do people implement the braces and the speaker itslefs? when I put that in the hornresp design your cros-sectional area change, the only way I see it when there is a 18 mm brace I have to extra widen the box to get the same area again, or do I see this wrong? I can tread the braces also as a cross sectional area, better I need to do that and fill in that extra space in hornresp, some do 20-30 procent extra to the outcome of hornresp.
Do you like the graph in the post 3953? I now did only measure s1 s2 s3 s4 and drawn a straight line like you say, I think with a notch or damping I get to 100 Hz bandwith with some loss of efficienty.
I go try to find some more info, the tapped horn treads are sometimes very very big, special if i am there:-)
Old 17th March 2013, 08:21 AM   #3956
Hi kees,
That is the correct approach to take.
The SPL response curve from 20-70Hz looks fine to me :-).
Kind regards,
David
www.hornresp.net
Old 17th March 2013, 02:32 PM   #3957
Hi David, Thanks for your help, now I now what to do and how, the LE in your program
do this also include the coil for the crossover? do I need also include resistance of that coil in the speaker RE in hornresp?
And that is all I need to now, nog learn folding what is more difficult if I use longer L12.
regards and thanks again learn me using your wonderfull software.
kees
Old 17th March 2013, 09:09 PM   #3958
Faulty respons, sorry
Old 17th March 2013, 09:13 PM   #3959
Ahh I did not now everything, One thing resists.
The outcome see pictures, here I have a strange outcome but a very good graph, The question is precisely on the center of S2 or S3 where the speaker is I can not assemble the speaker because there is a angle there, what do you in such case put the speaker on the back of the horn? so it will fitt on that angle, I hope you understand what I mean, my english in technical form is not as good.
This grahp from hornresp is from two speakers, I can put them like it is in TH-Spud tapper horn, but this is nog a real tapped horn, more a combination of a tapped horn and a T-TQWT, the question here is about one speaker, if there is a bend on S3 or S2.
see exort sketchup the circle on S2 this box is just a testing for me, I even have not that mivoc speaker.
Have a nice weekend.
kees
Old 18th March 2013, 06:07 AM   #3960
Hi kees,
Someone with practical experience in constructing tapped horns would be in a better position than me to answer your latest questions.
Kind regards,
David
www.hornresp.net
Collaborative Tapped horn projectHide this!Advertise here!
