Collaborative Tapped horn project
Old 11th February 2013, 11:08 PM   #3871
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
35% longer ? wow, that much
hey, here's a really weird one
maybe I should just fold some paper instead
time for me to cool down
Old 11th February 2013, 11:45 PM   #3872
tb46 is offline tb46  United States
Hi tinitus,
Actually, that's a really cool fold. You should work it out into an actual example.
Oliver
Old 11th February 2013, 11:57 PM   #3873
weltersys is offline weltersys  United States
weltersys's Avatar
Making line drawings can be deceiving, once you add in the actual wood thickness you often will find not as many folds will fit in the space you want.
Old 12th February 2013, 04:35 AM   #3874
epa is offline epa  Netherlands
fyi
i was talking about the difference between simulated volume vs actaul bild volume.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 12th February 2013, 06:24 AM   #3875
ah, yes...thanks
always do a full size drawing
I expect it would work with smaller woofer, and not too low
Old 12th February 2013, 10:38 AM   #3876
he, crazy foldings
Old 12th February 2013, 10:43 AM   #3877
mrduke is offline mrduke
Default double 3 inch
Hi, started playing around with Hornresp a little ago... the wizard is great fun. But I would like to run a sanity check with you guys. I have simulated a TH with two Aurasound NS3-193-8 (mainly because I have a couple of leftovers), and I sort of think the result looks too good to be true. That generally means something is off. Please have a look, feedback is appreciated.
Nominal Diameter . . . . . . . . . . . . . . 3 inches (70 mm)
Nominal Impedance (Z) . . . . . . . . . . 8 Ohms
Sensitivity, 1W/1m (E) . . . . . . . . . . . 80 dB @ 1 kHz
Power Capacity, RMS (Pe) . . . . . . . . 20 W
Power Capacity, Peak . . . . . . . . . . . 80 W
Frequency Range (-10dB) . . . . . . . . Fo - 15 kHz
Minimum Impedance . . . . . . . . . . . . 8 ohms
Voice Coil Diameter . . . . . . . . . . . . . 19.3 mm
Voice Coil Winding Length (h) . . . . . 6.5 mm
Voice Coil Number of Layers (n) . . . . 4
Voice Coil Former Material . . . . . . . . Kapton
Voice Coil Wire Composition . . . . . . CCAW
Magnetic Material . . . . . . . . . . . . . . Neodymium radial
Stray Flux Shielding . . . . . . . . . . . . . Inherent
Magnetic Gap Depth (He) . . . . . . . . 12.7 mm
Cone Material . . . . . . . . . . . . . . . . . Aluminum
Surround Material . . . . . . . . . . . . . . Rubber
Polarity, Outward Motion . . . . . . . . . Positive voltage on (+) tab
Net Weight . . . . . . . . . . . . . . . . . . . . 216 g
Thiele / Small Parameters
Resonant Frequency (Fo) - Fs . . . . . 80 Hertz
Voice Coil DC Resistance - Re . . . . . 7.6 Ohms
Total Q - Qts . . . . . . . . . . . . . . . . . . 0.67
Mechanical Q - Qms . . . . . . . . . . . . 8.0
Electrical Q - Qes . . . . . . . . . . . . . . 0..73
Equivalent Volume of Air - Vas . . . . . 1.25 L
Radiating Piston Area - Sd . . . . . . . . 31 cm
Xmax . . . . . . . . . . . . . . . . . . . . . . . . 10 mm peak to peak
Electrical / Mechanical Parameters
Flux Density x Length - BL . . . . . . . . 4.7 Tesla-meters
Compliance - Cms . . . . . . . . . . . . . . 920 Ám/N
Total Mass - Mms . . . . . . . . . . . . . . 4.3 grams
Old 12th February 2013, 02:08 PM   #3878
from here it looks ok,only the input voltage should be 2 volts for 4 ohm(8+8/2)for 1w/1m
. hr driver db
Old 13th February 2013, 08:08 AM   #3879
Ah yes you are right! Now the gain seems a little more reasonable, thanks!
Old 13th February 2013, 11:27 AM   #3880
pulling this very nice 15" out of my bass guitar cab (to try a differnt model with more midrange extention)
fortunately FaitalPro have been clever enough to size all their 15" woofer chassies equally, even when of different designs
so I may have this to try in a sub, either BR, or 6th order BP
6th order seem to end on 100liter netto, so that seems quite ok
but would also like to know how it would work in TH
anyone want to model it for me ?
http://www.faitalpro.com/products/fi...atasheet_8.pdf
Collaborative Tapped horn projectHide this!Advertise here!
