Collaborative Tapped horn project
Old 3rd October 2012, 12:08 AM   #3861
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
thiele small specs
looking at a big PA woofer
it clearly says 22hz ressonance
and graph shows it too, or close
but its listed with 34hz Fs in thiele small specs for box calculation
why is that
or is 'just' to be conservative and avoid failure ?
meaning it could be calculated using the 22hz ?
Old 3rd October 2012, 12:24 AM   #3862
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by tinitus View Post
thiele small specs
why is that
An inaccurate Fs figure is more likely to make a speaker/cabinet alignment failure prone.
A speaker with a 34 Hz Fs can be put in a box with a 22 Hz Fb or Fc.
By "22hz ressonance" do you mean Fb or FC?
Pictures of what you write about would be helpful.
Old 3rd October 2012, 07:07 AM   #3863
Originally Posted by weltersys View Post
An inaccurate Fs figure is more likely to .....
its the new Precision Devices PD.1851
22hz ressonance is clearly the ressonance peak
but they still use 34hz for thiele small Fs
Old 3rd October 2012, 11:03 AM   #3864
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi tinitus,
If you place Your 'hand' at the smallish FR or on the impedance graph you will realize that 22Hz is the PD 2150 fs and not for the PD 1851.
b
Old 3rd October 2012, 01:47 PM   #3865
shoot, you are right
specs shown on the new PD.1851 clearly says PD.2150
weird mistake, but its a new site layout
ok, thanks
Old 3rd October 2012, 03:21 PM   #3866
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by Skiivari View Post
Just a few pages back, bjorno's version. Collaborative Tapped horn project
definately not getting into the low 20's with this much stuffing (or leakage)
musically I'm really happy, it sounds good and my mains can't keep up
I see your design has something in common with mine, car audio driver in a tqwt
Based on the 25hz tuning and recommended 25hz/24db filter, you're not going to get low 20's. Nice response for such a short length ttqwt!
Yes it does. I love it! I have no stuffing or highpass filter. It's a beast! I designed it for 1, 000 watts but only putting about 200-250 to from a Yamaha htr running in subwoofer mode from a Sony htr. D@mn thing has cracked multiple walls in the house.
Old 11th February 2013, 10:50 AM   #3867
looking at a woofer
http://www.lautsprechershop.de/pdf/m...320hc_data.pdf
for mounting woofer, I thought if most of the whole side could be removed to do that, it would also be possible to 'adjust' the last horn path and opening by changing this baffle part
anyone tried to make lots of smaller holes close to opening, like the did in the older days to achieve apperiodic system, or slits, slots, or whatever ?
well, anyway, if that baffle part is made detachable it would make experimets possible
Old 11th February 2013, 12:36 PM   #3868
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Anyone tried to make lots of smaller holes close to opening, like the did in the older days to achieve apperiodic system, or slits, slots, or whatever ?
What you sketched and described Looks exactly like Art Welters Keystone TH Cabinet.
Keystone Sub Using 18, 15, & 12 Inch Speakers
Old 11th February 2013, 03:23 PM   #3869
great, thanks
ok, because of its 'cubic' size, it may in reality need another folding, and end more like this
are there any 'average' rules about needed volume in liter, that could tell me about estimated size ?
Old 11th February 2013, 03:44 PM   #3870
epa is offline epa  Netherlands
if one uses 18mm ply ad 25 to 35% to the simulated value.
the more folds the model has the more "unused/not simulated" corners it has.ie in your last example it wil be closer to 35%
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Collaborative Tapped horn projectHide this!Advertise here!
