Old 29th November 2011, 04:33 PM   #3731
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by 454Casull View Post
The impulse response looks very poor and I can't figure out how to make it better.
IMO, Thats a layman's opinion based on visual interpretation of an IR that cannot be deduced without slicing up the response in pieces and that must be evaluated with psycho acoustical scales if to be of any value.
What's wrong with the IR?
b
Old 29th November 2011, 05:35 PM   #3732
b
I don't have access to Hornresp right now but there is no positive portion to the waveforum, IIRC.
Old 29th November 2011, 06:27 PM   #3733
I've reached my limits for to verbally understand your sentence.
b
Old 1st December 2011, 03:43 PM   #3734
If you look at this in-room measurement of my TH driven by a 2.1 amp based on LM something used in crapola devices.
http://img263.imageshack.us/img263/9861/ircompare.png
Where is the oh so bad IR from a TH?
Compared to an ideal Q0.577 simulated with a rolloff at 30Hz
Hornresps imported IR is not far of when lowpassed the same way.
The point is that you have to low-pass the IR to get anything meaningful out of it, else you are chasing ghosts.
Old 2nd December 2011, 03:04 AM   #3735
b
sorry
see attached
Old 3rd April 2012, 06:39 PM   #3736
Patrick Bateman's Avatar
Originally Posted by Puggie View Post
After a productive morning reading this thread could someone be so kind to throw this driver into hornresp or similar, I'm currently Mac-ified and until I sort out my PC at home I cannot do much modeling
Overall diameter: 215mm (8.5-inch)
Sensitivity: 87dB (2.83V/1m)
Mms: 31.5g
Cms: 454 um/N
BL: 5.99 T*m
Voice coil diameter: 35.55mm (1.4-inch)
Impedance: 4 Ohm
DC Resistance: 3.4 Ohm
Fs: 40Hz (free air)
Qms: 7.35
Qes: 0.693
Qts: 0.765
Xmax: 8.5mm (one way)
Vas: 26L
Sd: 0.02 m 2
I'm looking for a relatively small tapped horn if possible, that can reach under 30Hz (20 if possible) I'm hoping a small footprint and tall enclosure will have sufficient WAF!
I have a couple of other options in 8" drivers if that isn't suitable (but reading this thread I hope it is).
I am running both Akabak and hornresp on Ubuntu using VMWare Player.
Seems like everyone is buying Macs these days, and I don't imagine that Akabak will ever get ported to OS X, or even Windows 7!
So VMWare Player is absolutely great for this stuff.
Old 3rd April 2012, 06:45 PM   #3737
Originally Posted by 4pyros View Post
I dont think a tapped horn should be smaller just louder.
I'd argue it's the other way around. Tapped horns aren't necessarily louder than front loaded horns. They're simply a novel way to horn load a woofer without using a huge box.
IE, due to Hoffman's Iron Law the efficiency between the two is comparable, but tapped horns give us the luxury of making the enclosure smaller than would be practical with a FLH.
A few years ago I used to argue on this forum that the TH *was* more efficient, but I no longer believe that is the case.
Oddly enough, one could argue that a sealed box is superior for infrabass than a tapped horn. So a tapped horn's best place to shine may be the range from about 40 to 160hz, oddly enough.
Old 3rd April 2012, 06:56 PM   #3738
Front and rear loaded horns are designed around a 1/4 wave, while tapped horns use 1/2 wave. Therefore the tapped horn is theorically bigger. Ironically, the RLH has the peak resonance at its 1/2 wave. Basically, I'd say it's a cheat to say that RLH are based on 1/4 wave . Per exemple, a JBL 4520 has 1/4 wave at 35Hz, but the real bump (1/2 wave) is at 70Hz, where it has the highest output.
Old 3rd April 2012, 08:35 PM   #3739
GM is offline GM  United States
GM's Avatar
Horns are 1/2 WL resonators same as an open pipe except with a 1/4 WL fundamental.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 4th April 2012, 09:29 PM   #3740
obeman is offline obeman  Finland
Send a message via MSN to obeman
B&C SPEAKERS
21IPAL
2500w (AES)
80 mm peak-to-peak
15..22mm linear peak
Flux Density 1.35
FS 37HZ
:O
Page generated in 0.15105 seconds (75.93% PHP - 24.07% MySQL) with 11 queries
