Collaborative Tapped horn project
Old 19th October 2011, 01:39 AM   #3721
tb46 is offline tb46  United States
Hi Skiivari,
I agree, for a proof of concept it would be nice to at least know the T/S parameters of the driver involved (and the parameters you have for this driver don't seem correct).
Oliver
Old 19th October 2011, 02:33 AM   #3722
GM is offline GM  United States
GM's Avatar
Originally Posted by tb46 View Post
Hi Skiivari,
Your Mmd=41.08 looks low for a 12" horn driver. What driver? Manufacturer? Model number?
Pretty typical for a 'vintage' prosound vented mid-bass for small scoop bins or 1:1 CR, expo flare FLHs. I assume it doesn't have much usable excursion, so with a low Fs-high Vas, not really a TH candidate except in a very large cab, though a T-TQWT should work well in considerably < 320 L with the trade-off of course being less acoustic efficiency/peak SPL. Not many 'free lunches' in audio.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th October 2011, 03:30 PM   #3723
Hi GM,
Interesting, I figured to get the Mmd down that low the voice coil would have to be light in addition to a light weight diaphragm.
Looking at the T/S parameters some more: the Re=8 Ohm looks like somebody type in a nominal value, and the Sd=460 cm^2 is smaller than I would expect for a 12" driver. Both parameters have a strong influence on the simulation.
But Skiivari can measure all of the above to arrive at data that he can trust.
Oliver
Old 12th November 2011, 11:44 AM   #3724
Skiivari is offline Skiivari  Finland
Hello guys.
I gave up on the mentioned driver and any type of horn.
Now I got 2 eminence 6's from my friend. The model doesn't read on the back and It isn't any one of the newer eminence 6's mentioned on their site. What they most resemble is the closed basket 6 except they have an open basket.
Specs are: (Self measured )
Fs= 76hz
Qms= 6.77, Qes=0.82, Qts= 0.73
Sd~~ 123 sq cm
Vas with 123 sd = 9.77l
CMS=4.53E-07(?) I have used E-04 in the sims as I think the spreadsheet has it in mm or something..
It doesn't really want to go much under 37ish hz in a nicely sized enclosure. I'm fine with this. 75l seems to be a sort of optimum one.
One question: is there a problem with going up to 120hz on a sub if it's corner loaded? Don't the sound waves start getting all directional etc?
Old 12th November 2011, 02:07 PM   #3725
Hi Skiivari,
Your T/S values (Re=?) look reasonable in Hornresp. I end up with a 70L tapped horn.
As to the corner placement, it depends on your setup. E.g.: if you have two corners symmetrically aligned behind your main speakers, and two subwoofers the time alignment would be more of a concern than the cut-off frequency. I'd play it by ear :-).
Oliver
Old 12th November 2011, 02:37 PM   #3726
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Skiivari View Post
..I gave up on the mentioned driver and any type of horn...
HI Skiivari,
If you change your mind you could try a T-TQWT....In agreement with GM wrote in post# 3722:
b
PS:You mentioned earlier the IR for your FLH. Agree it looks bad. You can compare the wavelets in the submitted picture. In reality the T-TQWT uses damping materials in the path of the tapering resulting in a measured IR that would be superior to your HR FLH simulation too.
Old 29th November 2011, 05:06 AM   #3727
454Casull is offline 454Casull  Canada
Is this buildable?
Old 29th November 2011, 10:57 AM   #3728
R.I.P.
It's a 2.5m long tapered tube folded to form a TH.
What is not buildable?
regards Andrew T.
Old 29th November 2011, 01:35 PM   #3729
Hi 454Casull,
There are some folding suggestions, etc. in this thread:
http://www.diyaudio.com/forums/subwo...th-t-tqwp.html
Oliver
Old 29th November 2011, 04:16 PM   #3730
The impulse response looks very poor and I can't figure out how to make it better.
Collaborative Tapped horn projectHide this!Advertise here!
