Collaborative Tapped horn project
Old 20th May 2009, 04:48 AM   #3381
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Default Re: Eight subwoofers
Originally posted by j.michael droke
Hi there Patrick: Your system must sound great with distributed bass. I'm contmplating a multiple sub system and have a few questions: What connection scheme di you use? Wire (lots of wire)? Wireless? How many bass amps? Is there phase control in use? I recently read the Harman Int. study by Todd Welti, which studied the placement of multiple subs: what placement did you use? Baybe this subject should be in a diferent thread? ....... regards, Michael
It's basically an 8' x 8' platform that's about 8" tall. My couch rests on it. If you've seen the blueprints for the th-spud, it's basically the same idea.
It's not a tapped horn though; there are five subwoofers built into the platform.
In addition to that I have two bandpass subs and a tapped horn in the room.
I use a single plate amp. The power is weighted so that the platform gets a third, the TH gets a third, and the bandpass sub gets a third.
Believe it or not, the five subs run out of excursion before the tapped horn does. That's why they get the least power.
Old 20th May 2009, 04:55 AM   #3382
Has anyone created an Akabak model for dual woofers?
I threw one together this evening. It's quite an eye opener! The dual woofer design increased efficiency by almost double over the passband, and reduces third order distortion.
It's no wonder that Danley has released two tapped horns with dual woofers, and is about to release a TH with *eight* woofers. Multiple woofers work a heck of a lot better than one.
I posted the plans here:
http://www.diyaudio.com/forums/showt...5&pagenumber=3
It might be worth creating a model with three or four woofers too.
Since modeling these is complex, this is what I do:
#1 - I create a design in horn response.
#2 - I transfer the design to Xara (a 2d design program. You can use whatever you prefer.)
#3 - Once I have a 2d model that works, I go back to horn response and change the parameters so that they agree with the 2D drawing from Xara.
#4 - Re-simulate in Horn Response, to be sure that it still looks alright.
Now the tricky part...
You have to put the segments into Excel, so that you can figure out where the taps go. It's a simple spreadsheet really.
Once you have the new segment lenghts and volumes from Excel, put them into Akabak, and check out your new Tapped Horn!
If these measure half as good as they model, I think we're going to see a lot of people using multiple wooofers...
Old 20th May 2009, 05:49 PM   #3383
I created a model for a tapped horn with four woofers. Like the dual woofer version, it seems to flatten out response at the low end and reduce sensitivity at the high end. It should be a real distortion killer. The severity of the peaks and dips is reduced also. Here's a pic from Akabak. The image at the top is a single woofer TH, the one at the bottom uses four of the same woofer. The excursion plot is at the left, and it's a bit wonky (since the minimums occur at various frequencies.)
Old 20th May 2009, 08:15 PM   #3384
Frode is offline Frode  Norway
I have a pair of Aura 10000RPM subwoofers , is it possible to make use of them in a TH? They will be used in a small room(16sq.m/~172sq.ft) so I don't need much output. I would like to use them below 60-80Hz.
Frode
Old 20th May 2009, 09:23 PM   #3385
Frode
Prosound woofers and carsound woofers have worked better than your typical home audio woofer in tapped horns. They tend to have a higher FS. The specs on the Aura looks good. I'd get a copy of horn resp and start messing around with it...
Old 20th May 2009, 09:56 PM   #3386
I have Hornresp, but I have to admit that I struggle a bit with the TH-simulations. I guess I just have to read the whole thread properly.
Anyways, I've made a simulation(probably stole it somewhere in the thread):
It seems like it should be possible to get a decent result, so I'll just have to play around with Hornresp. I'm open to any suggestions.
Frode
Old 20th May 2009, 10:18 PM   #3387
David_Web is offline David_Web  Sweden
A reverse taper seems to work well with that driver.
Not sure how it would work in reality though.
450 to 100 seems impressive. But then I'd be worried about "port" noise.
A total of 3m length.
Construction might be a problem.
Juggle it a little more and you might find a compromise you are happy with.
Old 20th May 2009, 10:37 PM   #3388
Is this possible to sim in Hornresp?
Frode
Old 21st May 2009, 12:09 AM   #3389
GM is offline GM  United States
GM's Avatar
This driver wants a big cab, but considering the room size and the desire for two THs:
GM
File Type: gif aura 10000 rpm 14.57-132.45 hz conic th (reduced size).gif (15.6 KB, 871 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st May 2009, 12:23 AM   #3390
GM's Avatar
Sure, though DW's specs seem way too small to me (don't forget to use the combined response tool):
GM
Collaborative Tapped horn projectHide this!Advertise here!
Copyright ©1999-2017 diyAudio
