Collaborative Tapped horn project
Old 28th January 2009, 01:20 AM   #2831
FlipC is offline FlipC  United States
djk
Are those sub woofers in the picture you posted old EV or JBLs?.
Since the mid and tops are JBL...
Old 28th January 2009, 01:39 AM   #2832
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Default TANG BAND MEASUREMENTS
I did these measurements a couple of months ago. Hope I got the hosting figured out correctly!
http://picasaweb.google.com/mwmkravc...eat=directlink
Mark
Mark
www.kravchenko-audio.com
Old 28th January 2009, 03:35 AM   #2833
djk is offline djk
djk's Avatar
"Are those sub woofers in the picture you posted old EV or JBLs?."
They are custom, and have 8mm x-max. The cabinet tuning is 6th order vented with an F3 of around 30hz and 101dB/2.83V/1M (8 ohms). Two a side are 107dB/2.83V and a 4 ohm load.
"Since the mid and tops are JBL..."
The HF are JBL2380/2441, but the mids are custom fiberglass with custom drivers similar to JBL2202. The HF most often used with this set-up is the EV HP640/DH 1A.
Candidates for the Darwin Award should not read this author.
Old 28th January 2009, 03:48 AM   #2834
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally posted by tinitus
But if drivers are too far off, they may load each other badly under heavy load, ressonating and making things even worse
Well, Im just not so very sure about it
Sorry if you think Im being too critical towards this, but I am so even with things I believe in myself
In my world EVERYTHING has flaws somewhere, and I just like to find out exactly where the flaws are
Sorry, but thats just how I am
sometimes we know very little, and sometimes we know too much
Old 28th January 2009, 06:38 AM   #2835
Hi
I hope that you dont me posting this one again
It shows how its possible to have a pushpull with drivers loading each other less, or not at all, but still a perfectly summed output
Old 28th January 2009, 06:56 AM   #2836
Sorry, and once again, the taller and simpler version...not tapered, but only to show principle
Old 28th January 2009, 07:41 AM   #2837
Since I suck with Akabak can someone post a script for Tinituses fisrt pic there
Old 28th January 2009, 11:15 AM   #2838
Sabbelbacke is offline Sabbelbacke  Germany
@mwmkravchenko
Thanx. I was talking about the klippel measurements. Those were the ones I meant:
http://www.diymobileaudio.com/forum/...omparison.html
The TangBand is a little monster and I like it It does a good job in Bill Fitzmaurices Car-Horn, in several closed or ported installations, small tapped horns... But the suspension and the motor isnīt linear at all, compared to other 8". But for the price, itīs almost the only one (with the parts express euivvalent) with a very rugged cone, enough BL and high x-max...
Old 28th January 2009, 12:30 PM   #2839
JLH is offline JLH  United States
JLH's Avatar
Originally posted by Sabbelbacke
No, xmax of the tangbands is 12mm one side, so itīs 24mm p-p
Somewhere at another diy-site there was a klippel measurement of 8" car-subs. The Tangband has a poor BL-Curve, so putting it into an isobaric configuration (push/pull) is a very good idea.
Sabbelbacke,
You are absolutely correct. Looking at the Bl curve below, it can be seen that the 71% (Xmag) point becomes +17.5mm and -17.5mm when the W8-740 is used in push-pull. This lets us pick up and additional +/- 2.5mm than what is spec'ed for the woofer. Yummm..... more Xmax and higher peak SPL. This is the best way to use this woofer.
Old 28th January 2009, 01:12 PM   #2840
JLH's Avatar
After taking a closer look, allow me to correct my above post. The W8-740 actually does better than +/- 17.5mm in push-pull. See below picture.
Collaborative Tapped horn projectHide this!Advertise here!
