Collaborative Tapped horn project
Old 27th January 2009, 03:34 PM   #2821
tb46 is offline tb46  United States
Default THSUB_couch
I spend a little time drawing the THSPUD_couch in ACAD to arrive at the dimensions needed for hornresp. Obviously the positions for S2-S3-S4 are somewhat arbitrary, but close enough.
As GM pointed out, it seems to model just fine with the TRIO-8; and as Cowan has already stated - a few times - at the frequencies involved the two speakers behave like one.
Regards, Oliver.
Oliver
Old 27th January 2009, 03:54 PM   #2822
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hi
Thats nice
Would it be possible with a version with measures converted to metric(mm) ?
Those fine woofers are affordable, and I hope to order a pair and pay the additional cost, I think they are worth it
sometimes we know very little, and sometimes we know too much
Old 27th January 2009, 04:17 PM   #2823
Hi tinitus,
For a handy unit converter go to
http://www.joshmadison.com/software, and get convert.exe.
Also, see the link Volvotreter posted in Post #2819.
Oliver.
Oliver
Old 27th January 2009, 04:55 PM   #2824
Thank you
One more small point
I think it should be written on drawings which drivers are used anyway, I will use the trio8 so your drawing is real good, bookmarked and renamed
Old 27th January 2009, 05:43 PM   #2825
Hi Oliver
May I ask you, which TB woofer is used fore the original "thspud couch" shown in post "2823"
thanks
Old 27th January 2009, 06:36 PM   #2826
Hi tinitus,
I don't have any driver information beyond the "Double Driver Tapped Horn" thread:
http://www.diyaudio.com/forums/showt...48#post1718548
Oliver
Old 27th January 2009, 06:59 PM   #2827
Volvotreter is offline Volvotreter  Germany
Volvotreter's Avatar
The drivers in these pictures were identified by JLH here.
Old 27th January 2009, 07:50 PM   #2828
OK, thanks
W-740P or W8-740Q...foam surround, that will be the W8-740P
and mr Danley used those, interesting
I expect that the 12mm Xmax is (p-p)
If I remember correctly the Trio8 has twice that Xmax
Just looking at Trio8
Something seems strange
Voicecoil....16mm height
Xmax 28mm(p-p)
And very thick poleplate
Maybe some calculated effect of the XBL, or an error
Old 27th January 2009, 07:53 PM   #2829
Sabbelbacke is offline Sabbelbacke  Germany
No, xmax of the tangbands is 12mm one side, so itīs 24mm p-p
Somewhere at another diy-site there was a klippel measurement of 8" car-subs. The Tangband has a poor BL-Curve, so putting it into an isobaric configuration (push/pull) is a very good idea.
Old 27th January 2009, 09:47 PM   #2830
Logically true isobaric should work more effectively than the "ordinary" pushpull
Only, its said that Isobaric is prone to go into not wanted ressonance, if drivers are too different
I especially like the beauty of the way pushpull is used in tapped horns
To me it seems like it presents a perfectly summed acoustic output, both ways...and drivers dont load each other too much to give any problems, kind of like the best of both worlds...theoretically
To me it seems that a tapped horn is the only design principle that does that, that is if it really does work that way
But if drivers are too far off, they may load each other badly under heavy load, ressonating and making things even worse
Well, Im just not so very sure about it
But I will do it anyway
At some point I was thinking that when using a single woofer, its mostly with magnet "out", which means that it is loading the horn throath in the direction where its strongest, namely forward...dont if that makes any sense at all, or whether the driver is loaded equally in both directions
Collaborative Tapped horn projectHide this!Advertise here!
