Collaborative Tapped horn project
Old 11th April 2008, 04:09 AM   #1501
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
th46: Thanks for giving the 4012 a go. It's good to have something to compare your results to...
I've had a look at my drivers tho, and I've actually found that they are the Eminence Magnum 12HO which is pretty much the same driver as the 4012, but I put in the new specs anyway as there are a few differences.
This is the first time I've used hornresp, and it's a pretty full-on... I've tried a similar sized TH with the Mag 12HO, and it's not too bad. I put in values for SD1 and SD5, and let the tapped horn wizard do the rest... The rest is pretty much wild guesses so far, apart from I know that SD shouldn't go over a 1:3 compression ratio in order to save the drivers cone... I need to do some reading up on hornresp really...
My attempt:
Old 11th April 2008, 04:14 AM   #1502
MikeHunt79's Avatar
I also have 2 Pioneer car subs which are in reflex enclosures right now, and sound pretty poor. I thought I'd have a go and see if these are any good in a TH... The model number is TS-W305C, and it's a 12" unit, even tho the cone is closer to 10" really.
The box works out quite a bit smaller, and it's still good around 20Hz.
If I built 2 of these TH's, and put the mouthes next to each other, would I get more extension like you get with normal front loaded horns?
Old 11th April 2008, 07:23 AM   #1503
Don Snyder is offline Don Snyder  United States
I decided to give AkAbak another try. I was redirected to a page where they were downloading v.2, but it's crippled and they want $700 for the full version. The old version / demo is no more.
Can anyone toss me a copy?
Old 11th April 2008, 08:32 AM   #1504
threadlock is offline threadlock  Philippines
hi don,
I got a copy here but I can't send you an email because Im still a newbie and my account is in moderation, could you post your email instead?
Old 11th April 2008, 08:44 AM   #1505
kstrain is offline kstrain  Scotland
Default AkAbak
Hi
you mean that
http://www.randteam.de/download/dl.p...kabak_Download
does not work for you? (I just re-installed from there and it runs on XP SP2.)
Ken
edit: typo
Old 11th April 2008, 02:57 PM   #1506
boydon_lepasci is offline boydon_lepasci  United States
Alright gang, here's another cry for help. I have a driver designed for a leaky sealed box(car door) that is available as a first TH candidate. I would like to use it to supplement my computer speakers from 30-100+Hz. Max SPL is not critical, but minimal size is. This is foremost a learning project, so any specific goals for end use can be suppressed if I get a listenable result and improved understanding of the design process. I am attaching my best results, but I seem to be an octave too low. Hopefully some of you will be able to clear the cobwebs from my mind.
Old 11th April 2008, 03:10 PM   #1507
Don't know what happened, but everything's fine now. I was using an old link, and got redirected and lost. Could be they were doing some mods, and I fell into a hole.
Anyway, thanks!
Old 11th April 2008, 05:25 PM   #1508
GM is offline GM  United States
GM's Avatar
Then make it shorter. BTW, what's its model number and Xmax for my records? It makes a ~theoretically ideal woofer TH, though of course much too large for your app at ~745 L:
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th April 2008, 10:24 AM   #1509
MikeHunt79's Avatar
^ Wow, that's a lot of SPL from such a small driver!
Right, I'm slowly working my way thru this huge thread, and I'm slowly getting to grips with hornresp. Now, I've got a JBL GTO 1202D car woofer that look like it might be ok... Specs here:
http://manuals.harman.com/JBL/CAR/Bo.../GTO_1202D.pdf
The Fs is a little low tho, but it's a DVC driver... I was wondering the best way of modeling this in hornresp as it can either have an impedance of 1 or 4 ohms depending in weather you wire it in series or parallel.
EDIT: Is there any way I can make this a little flatter, or will this sound ok it only varies 1 or 2 db between 20-80hz? This is the pioneer car sub, fwiw.
Old 12th April 2008, 08:52 PM   #1510
It's a 6-1/2" midbass from an MTX RT260S component set. Unfortunately I don't have a datasheet with Xmax on it. The TS parameters I am using are from the Woofer Tester II. Could you post the input window that goes with that SPL plot? I'm still trying to get the hang of picking flare rates and adapting them to the desired BW(using Leach's math via ML Util) and efficiency.
Collaborative Tapped horn projectHide this!Advertise here!
