#1101 | |
#1102 | |
Good stuff - thanks for posting this. I've modelled some TH with this driver that look awfully similar to what you built, so it's very cool to see that they deliver in the real world. I have two W8-740c drivers already, but at the price I may pick up some of the 6.5's and take advantage of the even smaller size. |
#1103 | |
15 V to 12.29 mm/18 Hz, so ~56 W. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#1104 |
Something i just realized by playing in Hornresp...
If you have found a nice TH design, but want to go an octave lower, you can use the same driver, you only have to use 4 of it, double the length of every horn segment and multiply every area by 4. this gives nearly the same response, only transposed one octave lower. This probably files under the "i found out something which was obvious to all others" topic BTW, does someone know, why the 18 Sound 15LW1401 for example gives such a great response in tapped horns? Its response is really flat and extended into the midbass, without the usual dips and peaks. Are there more drivers, that model so well, maybe smaller ones? |
#1105 |
good evening,
here is the promised sketch on how I do the folding: How to fold It is not a 100% accurate but I think it is acceptable, easy and quick. @tb46 I would describe the sonic differences as following: Both tapped horns sound very good. The sound is effortless and well controlled. Exactly what I was looking for. The bigger sounds a little better than the small (even more relaxed). The lower the better it sounds. Just very pleasing for the ears. For me both TH's are equally well suited for music as well as HT. Both are capable of doing big bad growl being required to reproduce tension and depth. But same here: The larger does it a little better but that doesn't mean that the smaller ones are insufficient. They are more than enough I think. You'll need very forgiving neighbors to drive them to the limits. Using 24dB/oct seems to be fine. I did not test different slops though. Yesterday evening we installed them at my friends place. They are intended to support his off the shelf magnat system on the bottom (2x 6,5" aluminum cone and 1" ceramic dome in d'apolito). When crossed over at 40Hz (evening out the rising response) they perfectly mate up with his mains xing in at 75Hz. It doesn't need high levels - even on low levels it sounds very nice. He and another buddy were quite impressed (especially when considering the investment). best wishes. Erik
#1106 |
After studying tapped horn/pipe designs for a while, one question remains in my mind. Most designs others and I have found feature high acoustic gain peaks in the frequency range just above the first null above the pass band (e.g. around 100 Hz and up in recently posted examples). These peaks amplify distortion by as much as 10 or 20 dB, and that could be potentially very audible 5th harmonic of ~20 Hz.
Now given how very much more audible 100 Hz is than 20 Hz at a given SPL, and noting that the gain at 100 Hz (or nearby peak) is large, why is there not more comment about the harmonic distortion in TH subs? The higher efficiency of TH for a given volume allows half the excursion that would be needed in a direct radiator, and so the distortion is somewhat smaller. It would seem however, that a sine sweep would still reveal distortion peaks corresponding to those pipe/horn modes. Has someone tried? I realise that the typical hornresp models might not be spot on with respect to the Q of the modes (due to unmodelled loss) but nevertheless I feel I must be missing something or THs would be less attractive than they are. I'm on the point of buying wood, but have reached a state of indecision over the significance of the aforementioned response peaks. Quite the opposite of bandpass action as in unity horns, where the HD is suppressed. I find the HD in my reflex sub easy enough to hear, at times, if I play it a bit loud. Ken |
#1107 |
kstrain, i build my first TH out of 10inch hifi woofers, they sounded better as in the previous bassreflex box, went deeper, were louder. i was really amazed. they had also these peaks in the upper response, but they sounded nice crossed at 50hz.
There are drivers, which have no such peaks, and roll of nicely. cowanaudio mentioned a few. |
#1108 | |
MaVo, can you post the Hornresp simulation for those 2 drivers
Killjoy or is it Chipsahoy |
#1109 |
Hi Erik: Thanks for the review. I think I have a much better idea of what to expect now. As far as leveling out the response I still feel that a simple passive filter would be helpful, kind of like the recommended filtering for the RiPols, anyway, it is good to know that they are not as critical as the curves look.
kstrain: Attenuating the peaks with resonators would make the job of the crossover much easier, and probably address your concerns. Obviously, this would require before and after measurements and respective tuning steps during the construction, and sofar the consensus seems to be that this may be more trouble than it is worth. But keep it in mind.
Oliver |
#1110 |
G'day kstrain
I think you touched on the truth in your post. Almost everybody here is showing graphs of modeled responses. The measured responses are usually smoother, most likely to do with the unmodeled losses you mentioned. Have a look at the red trace in this plot. It is the real measured unsmoothed response of a tapped horn. It shows out of band response peaks, but of a much lower magnitude than some of these models would suggest. BTW the plot is 6dB/div. so the 1st and second peak are about 3dB high. Just do the tapped horn and don't procrastinate. If the design is sound, you'll love the results. Cheers William Cowan |
| Page generated in 0.14652 seconds (77.79% PHP - 22.21% MySQL) with 11 queries |
