Collaborative Tapped horn project
Old 16th January 2008, 08:47 AM   #1011
Cordraconis is offline Cordraconis  Belgium
tb46: That sounds like an interesting design approach, might get structurally a little complex; resonators seem easier to implement. But, a really interesting AkAbak application.
Upon closer inspection I just noticed I forgot a comp chamber for the rear end of the driver. I'll give it a shot tomorrow.
The structural complexity might not be that bad after all: if my guess is correct that a front comp chamber can be left out, then only a back one would be nessesairly and if the motor assembly can extend into the resonator at the throat, then this back chamber can be as little as the space under the cone when the driver is screwed over a 1/2 sD hole near the mouth.
The resonator and the front chamber could be built into one but I first want to sim the effect of 2 separate ones first. So first I need to get the script working.
You speak of multiple resonators, but how would you implement that? I also considered several res at the throat, but since they all fire into the same throat wouldn't this couple all of them together into one resonant system as opposed to multiple separate ones?
The same could be true to some extent for my res+dual chambers idea, but I think this might be a bit different since comp chambers are not real helmholtz resonators and I see them more as acoustic compliance modificators.
that's it for today, off to work!
-- If in doubt: overdesign!
Old 16th January 2008, 03:14 PM   #1012
tb46 is offline tb46  United States
Default Helmholtz Resonators
Cordraconis: I'll try to attach some .jpg's that show some applications of Helmholtz resonators in loudspeakers, and a link to the E. Jakulis paper.
Back to work.
File Type: jpg giuliani nicoletti_voight_helmholtz.jpg (23.8 KB, 1135 views)
Oliver
Old 16th January 2008, 03:17 PM   #1013
And the next one, plus the link:
http://baseportal.de/cgi-bin/basepor...&cmd=all&Id=13
Oliver
Old 17th January 2008, 09:33 AM   #1014
ah, now I get it. Thanks for the JPG's. I'll have a look at the paper later.
So far I've put the back compression chamber and a corner loading reflector into the script but there isn't much approvement in the SPL plot.
The driver diaphragm displacement from akabak shows a gently sloping curve starting from 400hz till a whopping 2m (!) at 20Hz, which makes me think the driver isn't coupled to the system at all.
However, in the excursion dialog I can see the nodes and the connected components of the system so I'll try to use that to determine where the problems with my script are.
Clearly the learning curve of AkAbak takes longer than about 4 hours of educated cut-and-pasting-and-adjusting from the Help files.
Old 17th January 2008, 01:59 PM   #1015
Joseph Decker is offline Joseph Decker  United States
You might check in AkAbak that your 1 meter isn't actually 1mm. I just got into it, as well, to model tapped horns that hornresp wont. I was amazed to find displacement of 1 meter as well, especially at just .7 volts in, but if you double click the dark grey box that says(in my case)
"Uin=0.7Vrms"
"--TappedHor, N=2=3, Driver (diaph) 1"
It'll bring up a "Diagram Edit Range" Dialog, and you can see the vertical limits of the graph. My guess is that in your case it will tell you that the upper limit is 1 or 2cm and that the "1m" at the graph's edge stands for 1milli-.
On the subject of AkaBak, can anyone tell me if there is a way to get .5pi or 1pi predictions?
Joseph Decker
Old 18th January 2008, 10:14 AM   #1016
To add reflection (for 1/8th, ... 1/4th ... space ...) you have to define a reflector and put in the keyword reflection at the end horn or the last radiator. See my latest script below.
Getting a good sleep after 4 days finally paid off: I think I figured out the node-system of AkAbak and here is the result. This script looks more like I think it should behave.
Def_Reflector TopCorner
Left=1.0m Top=1.0m Right=1.0m
HAngle=45.0
Def_Driver 'SPH-212'
dD=21,2cm dD1=6,5cm tD1=2,5cm |Cone
fs=30Hz Vas=82L
Qms=2,21 Qes=0,5 Re=6,2ohm fre=8kHz Le=0.6mH
System 'RLDCTH'
Driver Def='SPH-212'
Node=1=0=200=300 |Driver connected to node 200 and 300
Duct 'FrontCompchamber'
Node=200=201 |driven by node 200 (front driver) and it drives/connects to node 201 (open end of resonator)
sD=0,110m2 Len=1cm Vf=20L
Radiator 'AfterFrontCChamber' Def='FrontCompchamber'
Node=201
x=0 y=0 z=0 HAngle=0 VAngle=0
Duct 'Resonator' |80Hz one end closed resonator
Node=0=201 |def "resonator" with node 0 as closed end and connected to node 202
sD=0,110m2
Len=100cm
Waveguide 'Conical Horn'
Node=201=301 |Conical horn between nodes 201 and 301
STh=0,200m2 SMo=0,300m2
Len=350cm Conical
Duct 'BackCompchamber'
Node=300=301 |Driven by back of driver and drives/exits in the conical horn
Radiator 'AfterBackCompChamber' Def='BackCompchamber'
Node=301
Horn 'Endhorn'
Node=301 |Horn driven by node 301 (conical horn+output back comp chamber)
STh=0,300m2 SMo=0,500m2
Len=60cm T=1
x=0 y=0 z=0 HAngle=0 VAngle=0 dEdge=3m Reflection
The Unity horn script MaVo posted some months ago, was most helpfull to give me the insight.
Now I have to do a direct comparison between HornResp and my script to see if they are similar.
Once again: if someone sees faults or errors in the above script, *please* point them out. Thanks in advance.
Old 18th January 2008, 07:23 PM   #1017
Killjoy is offline Killjoy  United States
Default Recent Sims
Here are some sims I have beenplaying around with. I have some for the Dayton Quatro 8".
Dayton Quatro 8" in TH ranging in volume from 100 - 150L. Is there any preference for hometheater? I have 2 more sims to come of the same driver. The sims are in order of smallest volume to largest.
Killjoy or is it Chipsahoy
Old 18th January 2008, 07:26 PM   #1018
Default More Sims for Dayton Quatro 8"
Here are the other sims for the Dayton Quatro 8". These have the voltage turned up until the driver reaches x-max.
Old 18th January 2008, 07:41 PM   #1019
Default Tang Band Comments
I tried changing the Qes from .3 to .4 on the 8" subwoofer and in the sims using Hornresp it starts looking pretty good. Would it be possible to adjust the Ques by varying the amplifier impedance as stated in this article:
http://sound.westhost.com/articles/cscaling.htm
If so then this driver may look something like this in a 117L TH:
Old 18th January 2008, 07:44 PM   #1020
Default Ciare 15 W2 TH
I'm going crazy with all of these nice looking results. Would this be relatively easy to x-over?
I forgot to change the Rg = 0.10 but I didn't notice much difference in my other sims when I made the change so maybe this is still valid.
Collaborative Tapped horn projectHide this!Advertise here!
