Old 15th January 2008, 01:13 AM   #1001
GM is offline GM  United States
GM's Avatar
Default Re: Sims
Greets!
OK, using my interpretation of ML's math and pipe horn design, I get a bit different gain BW/larger 377.394L with your axial length. Regardless, there's nothing wrong with your design if you plan to XO it down around 70 Hz, though many folks have worse dips in their rooms than this TH and don't mind it, so you may can XO it much higher if you prefer. Only one way to know for sure.
Note that since it's a 15" driver the minimum distance to the throat and mouth is 19.21 cm, not 15 cm and you need to put at least 0.1 ohms of series resistance in the 'Rg' field since it affects the sim. Also, PE's measured specs are somewhat different to the published ones, so I recommend trying them in your design before cutting any wood.
WRT finding power required to reach Xmax, either double click on the 'Eg' field to input watts/nominal load and re-calculate to see how it affects excursion or just input a voltage to see what it takes to reach Xmax at whatever cut-off frequency you choose, then calc watts required: W = E^2/R
With my sim it takes 20 V/100 W to reach the 10 mm Xmax at ~16 Hz, so with your lower tuning, though smaller TH, it's probably about the same.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th January 2008, 01:15 AM   #1002
GM's Avatar
plot:
Old 15th January 2008, 01:24 AM   #1003
Killjoy is offline Killjoy  United States
Default Re: Sims
GM,
I thought I read somewhere that the big dip around 60-70hz was a desired characteristic of TH? That this dip made it easier to XO? Your sim has the response looking more flat--is this more desired? I recall somewhere in this thread that a more sloping response would be desirable in a home setting. Should I make my results look more like yours and just EQ and be happy with the added headroom?
Killjoy or is it Chipsahoy
Old 15th January 2008, 04:09 AM   #1004
tb46 is offline tb46  United States
I have finally made it through this thread and cannot help but wonder if somebody has done some work on trying to tame the response with Helmholz resonators similar to the design example by E. Jakulis on a TQWT (tapered quarter wave tube)?
It seems that a similar technique would be almost necessary to optimize this design.
Oliver
Old 15th January 2008, 04:42 AM   #1005
Patrick Bateman's Avatar
Wouldn't that be more trouble than it's worth?
Hoffman's law tells us that high efficiency designs are always bandwidth limited, or require a huge box. In a lot of ways a tapped horn is like a dual reflex bandpass, albeit easier to build and tame.
Old 15th January 2008, 05:12 AM   #1006
GM's Avatar
Default Re: Re: Sims
Greets!
News to me, but if the two octave BW below it is all you need, then sounds like a good plan to me.
Yeah, I think I posted that since most rooms have some gain down low, but folks keep touting 'flat', so just going with the 'flow' WRT sims. In this respect, yours will probably perform better overall in-room than mine and it has enough headroom to EQ and still meet DD/DTS reference, not to mention it's the smaller of the two.
GM
Old 15th January 2008, 05:23 AM   #1007
GM's Avatar
Greets!
You can go through all that trouble if you want, I prefer to use a little stuffing if need be and let the XO deal with the rest of it., plus I gather that the 'ripple' isn't as bad as predicted. Anyway, if you make it big enough it all gets smoothed out enough.
GM
Old 15th January 2008, 03:34 PM   #1008
MartinQ is offline MartinQ  Canada
I believe this is one of the techniques that Tom Danley uses on his DTS 20. Perhaps he can 'pipe up' (hee hee) and give us feedback on how it's used and if it's worth it.
Old 15th January 2008, 04:21 PM   #1009
Well, I mentioned a few posts ago a combination of a helmholtz resonator and compression chambers on both sides of the driver to make a tapped horn more "bandpass". So this resonator would help as a lowpass filter around the desired upper cutoff.
After briefly discussing these ideas to one of the "Powers That Be" , he said I should give it a shot in AkAbak to see if there were any merits. Unfortunately by having to work again and not being proficient in AkAbak, I asked for help as my efforts stranded, but I still haven't got a reply.
Either he is too busy or quite possibly this was a silent hint to throw it in the group and let everybody help and benefit.
Anyway, here is the script I threw together:
Def_Driver 'SPH-212'
dD=21,2cm dD1=6,5cm tD1=2,5cm |Cone
fs=30Hz Vas=82L
Qms=2,21 Qes=0,5 Re=6,2ohm fre=8kHz Le=0.6mH
System 'RLDCTH'
Driver Def='SPH-212' Node=0=1=2
Duct 'Resonator' | 80Hz one end closed resonator
Node=0=3
sD=0,15m2
Len=100cm
Radiator 'AfterResonator' Def='Resonator'
Node=3=0
x=0 y=0 z=0 HAngle=0 VAngle=0
Duct 'FrontCompchamber'
Node=2=3
sD=0,15m2 Len=1cm Vf=20L
Radiator 'AfterFrontCChamber' Def='FrontCompchamber'
Node=3=0
Waveguide 'Conical Horn'
Node=1=2
STh=0,218m2 SMo=0,44m2
Len=350cm Conical
Horn 'Endhorn'
Node=2=0
STh=0,44m2 SMo=1m2
Len=60cm T=1
This is an effort for a group of different elements I tried to put into one system:
- the front of the driver loads a compression chamber to act as a lowpass.
- this compression chamber exits in a straight single ended 1/4 WL resonator tube for negative interference at the desired High cutoff.
- the open end of the resonator loads the throat.
- the back of the driver also loads a compression chamber for the same reasons as the front.
- this back compression chamber loads the mouth of the horn.
As you'll see from the SPL plot, it seems the resonator part works, but I have my doubts if I have the rest of the nodes correct, i.e. if the back chamber loads the mouth. Maybe someone else can clean this up? I'll much appreciate it.
It is interesting but not suprising - héhé - that Tom Danley seems to use the same ideas. I didn't know that.
Some more toughts about this:
- by tuning the front and back chambers I think it can be possible to adjust the apparent T/S parameters of the driver to better suit the TH. For example make the suspension more stiffer by higher compression ratios?
- Hornresp testing indicates the throat area should be fairly large with this particular driver, so maybe the front chamber should be omitted?
- the back chamber loads the lower frequencies into the TH, so there higher compression ratio's (and thus more filtering of the higher frequencies) can be beneficial and possibly reduce reflections into the horn?
- what will be the effect on the size of the TH? the more high freq you want to filter, the larger chambers you need so you get a larger TH ...
- will it actually work to divert the energy from the high freq for more output in the desired low freq passband?
Any toughts about this is much appreciated and I hope the above script in all its raw-ness is of *some* use to anyone ...
Joris
-- If in doubt: overdesign!
Old 16th January 2008, 04:56 AM   #1010
Hi again,
GM: I hope you are right and the response irregularities are not as bad as they look in Hornresp; I just doubt that a cross-over can eliminate the kind of spiking that is apparent in most of the SPL graphs. I agree, a little stuffing, or maybe lining of the horn path would probably help.
MartinQ: I think you are right. As you said it sure would be nice if Tom Danley could shine some light on this aspect of the subject. I cannot believe that all that nice volume from the speaker front to the bottom of the DTS-20 is just throat extension.
Cordraconis: That sounds like an interesting design approach, might get structurally a little complex; resonators seem easier to implement. But, a really interesting AkAbak application.
Thanks for all the advice and information.
Oliver
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
OzOnE_2k3
Page generated in 0.18535 seconds (77.01% PHP - 22.99% MySQL) with 11 queries
