Old 21st November 2007, 08:34 AM   #21
Default Re: Amplifier power and ohm loads???
Originally posted by LLDeese
If I run an amplifier that is rated at 1000 watts into 4 ohms with two 8 ohm speakers ran parallel they would have 500 watts going to each of them.
Is there any way to hook two 4 ohm speakers to a 1000 watt 4 ohm amplifier and get over 250 watts per speaker without running a 2 ohm load (parallel). Because the amplifier will not run a two ohm load (only rated for 4 ohms or greater).
yes, to first.
No, to second, unless the amp has an instruction that shows how to bridge it.
regards Andrew T.
Old 22nd November 2007, 02:09 AM   #22
LLDeese is offline LLDeese  United States
This amp is a mono amplifier for a subwoofer rated 1000 watts in a 4 ohm load, 500 watts in a 8 ohm load. So is there any way to run two 4 ohm speakers and get more than 250 watts per channel (running two 4 ohm speakers in a series)????
Because the amplifier will not run 2 ohm load (two 4 ohm speakers wired parallel).
How much power will two 8ohm speakers wired parallel in a 4ohm load receive???
Thank You for any help I can get.
Old 22nd November 2007, 09:04 AM   #23
connect an 8r0 load to an amplifier claiming to send a maximum of 500W into 8r0 and you will get a maximum of 500W.
Connect a second 8r0 load and the maximum amplifier output voltage will drop below that for a single 8r0 load. less drop = better output capability, (irrespective of what the dynamic overhead protagonists tell you).
Each 8r0 load should get 500W if the amplifier can meet it's specification of 1000W into 4r0 and 500W into 8r0.
What is much more likely from a conventional power amp is 1000W into 4r0 and 600W into 8r0.
regards Andrew T.
Old 12th April 2009, 09:46 AM   #24
Iliya is offline Iliya  Russian Federation
Guys, I am considering to build dual RiPol dipole subs using 18" Pro drivers and Dayton HPSA1000-R sub amplifier that was discussed above.
Drivers are available in 8 Ohm and 4 Ohm versions. Would it be better to use two 4 Ohm drivers in series or two 8 Ohm drivers in parallel connection? My understanding is that dipole subs do not require a lot of power do drive them to the limit. In what case will be there better damping of the drivers?
Zaph Waveguide Questions & Issues EDDIEMUNSTER Multi-Way 9 18th March 2007 11:27 PM
Gas tank and subwoofer issues? michael Car Audio 2 8th May 2006 09:48 AM
AR9 Subwoofer Questions dc270 Subwoofers 0 7th May 2006 12:17 AM
vented subwoofer vs room issues? Ilianh Subwoofers 8 14th December 2002 08:13 PM
Page generated in 0.07708 seconds (72.93% PHP - 27.07% MySQL) with 10 queries
