Ahh I havent been here in a while but I've got an itch to build a higher quality car subwoofer. I figure I'll put this in here rather then the car forum since more DIY enthusiasts frequent here.
Last night I tuned my car with my Velodyne SMS-1's analyzer (that I usually use in my home system). Put a display monitor on my hood and analyzed away. I adjusted the phase and EQ settings on my AudioControl crossover to optimize the sound. I currently use a commercially made 15" car sub (of decent quality but its stamped steel) in a 1.75 cubic foot sealed sonotube in the back of my car. As expected there is the typical car audio bump from 35-65 Hz. After the phase correction and EQing it sounds pretty good, however it only plays to about 33 Hz before it rolls off. i pushed the 25 Hz EQ a bit to get a little more extension but still its dissapointing. In a car it should be easy to get to 15 Hz. Sooooo.... I'm looking for some suggestions: I require: -High quality sound AND ability to get somewhat loud -Ability to play flat to 20 Hz in a sealed enclosure in a car with minimal EQ "push" -12" or 15" (or in between) preferably 15" -4 ohm, single or dual 4 ohm voice coil (no 8 ohm SVC's) -high power handling -Light weight -Passive radiator or sealed chamber (no bandpass or ported) - not to be ridiculously expensive -work in a 1.5-2.5 cubic foot enclosure I looked at Parts Express they have some Dayton drivers that look appealing, though the beefier ones are too heavy. Madisound recommended the following drivers to me: 1) 15" Aura Sound. Its too expensive and way too heavy so its out. http://www.madisound.com/cgi-bin/ind...56.6182&pid=98 2) Peerless XXLS 12" with 12" Passive radiator http://www.madisound.com/cgi-bin/ind....6182&pid=1790 3) Scan Speak 10" http://www.madisound.com/cgi-bin/ind....6182&pid=2012 http://www.madisound.com/pdf/scanspeak/26w_4867t00e.pdf High quality indeed, but from the specs and power handling it isn't gonna get too loud. I know this is a difficult preposition but right now I'm liking the Peerless 12 + passive combination right now. I'm all ears!
#2 |
1.5 cu ft. is really small for a 15" sub. If you want response down to 15hz you will need to build a low Q sealed sub. Something less than .65 should be good.
For car audio I like to use two drivers, pointed away from each other. This will greatly reduce mechanical vibration without requiring a very heavy enclosure. Since you have only 1.5 - 2.5 cu. ft. to work with, you would have to use two 10" drivers. Anything bigger will not give you the low Q you need. It sounds like your budget is around $300. How about a pair of Peerless 10" XLS drivers in 2 cu ft? Dan |
#3 |
Thanks for that reply. This is pointing me in the right direction. I looked at the Peerless driver, looks pretty good.
I remeasured my enclosure, it is actually 2.2 cubic foot. I'm starting to like the 2 10" idea. I'm going to crunch some numbers, I'm also considering 2 of the previous-mentioned Scan-Speak woofers. |
#4 |
Don't forget about cabin gain.
Design a sealed enclosure's F3 to fall within the cabin gain range and you're set. That's not difficult with most 15s. WinISD's forum has a thread detailing to model it with the Linkwitz transform function in the WinISD Pro software (free alpha release download), though a few graphs are null and void.
Got Bass? |
#5 |
Right, this is going into the back of a C5 Corvette coupe. I have the luxury that the woofer is actually in the same airspace as me (rather then in a trunk, for example). I'm not sure what the cabin gain is. The car is relatively sensitive to weight in the rear, so I'm trying to keep it as light as possible.
I use BassBox Pro and it does have transform function modeling, however like any software generated "theoretical calculations" it isn't always accurate. I calculated solid performance to 17 Hz with my current setup, but its obviously way off the mark It also does not do passive radiators. I may order the Peerless 12" with Passive Radiator. I've never played with a passive setup before and think it will be a sweet sounding rig without too much work. |
#6 |
Well I may have figured out why my current sub wasn't playing that low. The AudioControl 24XS crossover I'm using for bass/midbass has a preprogrammed 33 Hz, 18 db/oct high pass filter. WAY too high. Couple that with 15 Hz high pass on the Audiocontrol DQX low pass on the EQ unit and thats a major slope. I'm going to change the resistor values and hopefully reprogram it to 15 Hz and I'll report back.
I'm having a hard time finding 360K-480K ohm resistors though
#7 |
YUP! That's what it was. Turns out the local Radio Shack had 470K ohm resistors. Though they were 1/2 watt and 5% carbon. They will do for now. They were physically a bit large to fit in the slots so I had to pursuade them to go in. After I put them in the subwoofer definately plays lower, both to ear and to RTA. Woo hoo!
I will now order 1/4 watt metal film 1% resistors.
| How much weight does ABX carry? | Wellfed | Everything Else | 24 | 19th September 2004 06:17 PM |
| A weight vs. linear weight | gary f | Multi-Way | 1 | 2nd April 2004 02:23 PM |
| mdf weight | jeffm | Multi-Way | 6 | 21st November 2002 11:18 PM |
| Page generated in 3.54634 seconds (3.43% PHP - 96.57% MySQL) with 10 queries |
