General inquiries
Hello Everyone, My first project is a ht sub, I have 2 older 8" cerwin drivers that I'm going to wire in series and have a 200w cerwin plate amp I'm going use to drive them,
My first problem was that I was unble to get any t/s specs, I talked to Cerwin tech support and they were able to tell me that my drivers handled 150w required 0.75 cu ft per and each needed a 3x8.25" port @ 25 hz resonance
My questions are as follows,
Is there any "general rule" regarding driver and port placement?
Can I use 1 larger port to take the place of the dual 3" ports I require?
P.S. I do not have the equipment to test the drivers so winisd is not really an option
Thanks in advance, Scott
