Building Audiophile Sub with Peerless's XXLS 830845
Old 13th May 2007, 05:31 PM   #21
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
4(5)
Old 13th May 2007, 05:32 PM   #22
5(5)
Old 22nd May 2007, 05:55 PM   #23
Tiff_Needle is offline Tiff_Needle  Canada
I would Like to know if anyone can help e with the LT circuit for this specific sub (Peerless 12" xxls - 830845) with th Ruthmik Audio A370 Plate amp?
I'm considering on purchasing rithmyk's plate amp and chaging it's RC values to achieve a better set for my sub.
I've made some plots and I've come up with a 110,6 L sealed box!
Is'nt it a box too big?
Hi There again!
Wath would be the LT circuit values that you would recomend if I where to use the 12" XXLS - 830845 Driver with the Rythmik Audio A370 Plate amp?
Peerless specs (http://www.tymphany.com/datasheet/printview.php?id=30):
Electrical Data
Nominal impedance
Zn
8
ohm
Minimum impedance
Zmin
6.7
ohm
Maximum impedance
Zo
126.7
ohm
DC resistance
Re
5.9
ohm
Voice coil inductance
Le
3.6
mH
Capacitor in series with x ohm
Cc
uF
T-S Parameters
Resonance Frequency
fs
21.5
Hz
Mechanical Q factor
Qms
9.68
Electrical Q factor
Qes
0.47
Total Q factor
Qts
0.45
Force factor
Bl
13.1
Tm
Mechanical resistance
Rms
1.41
Kg/s
Moving mass
Mms
101.4
g
Suspension compliance
Cms
0.54
mm/N
Effective cone diameter
D
24.4
cm
Effective piston area
Sd
466
cm2
Equivalent volume
Vas
162.5
ltrs
Sensitivity (2.83V/1m)
88
dB
Ratio BL/(Re)
5.4
Ratio fs/Qts
F
48
Power handling
100h RMS noise test (IEC)
175
W
Long-term Max Power (IEC 18.3)
350
W
Max linear SPL (rms) @ power
dB/W
Short Term Max power (IEC 18.2)
W
Voice Coil and Magnet Parameters
Voice coil diameter
51
mm
Voice coil height
33
mm
Voice coil layers
4
Height of the gap
8
mm
Linear excursion +/-
12.5
mm
Max mech. excursion +/-
mm
Flux density of gap
mWb
Total useful flux
2.3
mWb
Diameter of magnet
147
mm
Height of magnet
35
mm
Weight of magnet
2.4
Kg
Rythmik Audio A370 Plate amp specs:
http://www.rythmikaudio.com/nonservo_product.htm#350se
Please take a look at the attachements
Old 22nd May 2007, 05:55 PM   #24
Sorry for the last post!
I did not notice that there where more replys on other pages!
I have to examine carefully all your replys and then post some questions.
Thank You all for your help.
I will keep you posted!
TIFF
Old 1st April 2008, 01:06 PM   #25
Hi there once again,
I've been out of the project for quite some time now since I've been working abroad.
I've read your replies and thank you all for your contribution.
I would like to take this opportunity to ask your opinion regarding the amplifier module that you would recommend.
I've been looking for a amplifier preferably with a XLR input and with a power reserve good enough in case I choose in the near future to go with a 2 subwoofer configuration.
I've looked in to the following choices:
*Hypex's DS8.0
*BK electronic's BSBPV500
and
*Rythmik Audio A370 amplifier - Special Edition (Non-servo)
all three of them are very different.
I prefer a more "musical" amplifier that's wy I'm considering a class A/B operation instead of a class D since I haven't got any actual listening experience with class D operation amplifiers.
I've listened once to digital amplifier's from lyngorf and they were ok but it wasn't the kind of musicality that search for.
Maybe today thing might have change a lot...
I've been told great things regarding Hypex amplifiers and the all well renowned BK amplifiers.
What are your opinions?
Tiff
Old 18th April 2008, 01:47 PM   #26
does anyone have an opinion on the amplifiers I'm considering?
Old 18th April 2008, 03:12 PM   #27
jb74 is offline jb74  United States
Default Speaker Identity
Tiff_Needle -
For what it's worth - the speaker photo in your post #1 appears
to be a Peerless 830877 12" XXLS Autosound Subwoofer
Old 2nd May 2008, 07:04 PM   #28
yes that is correct!
At the time I didn't have a photo of the peerless 830845 subwoofer but since they look almost the same I've posted one of the automotive model.
I've got both.. 1x 830845 and 2x 830777!
Got any opinion regarding my last question?
TIFF
Old 3rd May 2008, 03:00 PM   #29
Tiff_Needle
I have no experience with the amplifiers
mentioned in your post 25
But since your posted photo and your written
description did not match, I thought there was
a slight chance that you had a mislabeled product.
(I have on two occasions been shipped a speaker of that type that was not what it was labeled - from a well known US dealer)
Mistakes can happen.
Old 3rd May 2008, 11:43 PM   #30
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
G'day Tiff
Those 830877 drivers are excellent in a 20Hz Tapped Horn. Try running some models in Horn Response. You couldn't ask for more in a domestic environment!
Cheers
William Cowan
Building Audiophile Sub with Peerless's XXLS 830845Hide this!Advertise here!
peerless xxls sealed -vs- peerless xls with passive radiator Naudio Subwoofers 8 23rd March 2008 09:00 PM
Peerless 830845 Enclosure Drawings Needed lancer Subwoofers 3 5th May 2006 01:09 PM
Peerless XXLS 830845 suitability steve_mak Subwoofers 5 12th April 2006 04:13 AM
Plate Amp for XXLS 830845 ShockValue Subwoofers 2 24th October 2005 12:34 PM
FS: (2) Peerless 12" XXLS 830845 tf1216 Swap Meet 7 23rd October 2005 11:24 PM
