Hi, I am gigging with a pair of Peavey Sp118x BassBins. I love the sound I am getting, but the size of the cabs is getting me down. One person can't carry a bin on his own.
I used boxplot to try and design a new cab, but it came out even bigger. How small can I go when making a new cab? Would love to fit it into a cab the size of the wharfedale 18" bins. The drivers in the bins are 1808-4 SPS BWX. 4ohm. 500w cont. 2000w peak. vas: 311.7 / Qms:10.215 / Qes: 0.509 / Qts: 0.485 / Xmax: 2mm / sensitivity: 97.5db. PLEASE ... Any help and advice would be appreciated. Picture of Peavey Cab |
#2 |
I really thought someone would have an answer to my problem ... Or is the experts on holiday? |
#3 |
I guess they're,
The T/S-parameters of the speakers suggest to use it in a large to very large cabinet (like you do now). If you would make it smaller it would probably give a "hump" in the response a bit above tuning. If you want a smaller cabinet either use different speakers (lower Qts) or isobaric loading (which is quite foolish for PA-use, so forget I mentioned it). By the way, are you sure that Xmax is correct, it's really, really small. Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer. |
#4 |
You could look carefully at how much bass you really need. If it's regular rock'n'roll, there may not be much below 80 Hz (since on a bass guitar the 2nd harmonic is much louder than the fundamental). That could allow you to get away with a smaller box, and the peak could be a good thing if it reinforces the kick drum.
Or, just get yourself a hand truck or trolley or dolly to wheel the cabinets around with. |
#5 |
To me they look compact for a 18in cab. I doubt you are going to get anything smaller to work for you, given that you are working venues that require the use of an 18in cab.
#6 |
I also agree that reducing the cabinet size is not the best idea.... Perhaps put some casters on them, or get a hand truck... but if you really want something smaller with similar output you might have to look for new subs entirely...
The golden rule of DIY: Build nice, or build twice! |
| Tannoy 15" Reds for sale with crossover and cabs (local pickup for cabs) | saletel | Swap Meet | 0 | 27th October 2006 10:01 PM |
| how to reduce the size of my pic | Dusk | Everything Else | 1 | 23rd July 2005 04:36 PM |
| Peavey PA cabs - change ohm rating? | Skyline_UK | Multi-Way | 0 | 18th June 2005 02:36 PM |
| Help - Reduce Image File Size | ralph-bway | Everything Else | 1 | 11th March 2005 05:05 PM |
| Speaker size v Room size | cliffy | Multi-Way | 6 | 19th February 2005 08:34 AM |
| Page generated in 0.08567 seconds (74.68% PHP - 25.32% MySQL) with 11 queries |
