Hi all,
I'm seeking opinions on the results below. To my relatively untrained eyes this looks like 3rd order harmonic distortion 10 dB down from the fundamental frequency. And also 5th order 20 dB down, 7th order 30 dB down. The first result shows the measured response playing a 50Hz sinewave, and the second is 100Hz. Obviously all I'm doing here is using TrueRTA. Is this a valid test? I have to admit I have been using it for a few weeks in a temporary enclosure, and at usual low listening volumes this distortion is not obvious to me. I suppose I can't complain about the performance of a US $23 driver, but I was expecting the distortion to be a little lower than this. Andrew. |
#2 |
Second pic
#3 |
What is the drive level?
-10dB is ~30% distortion That is pretty high for 100Hz - you may want to make sure you are not overdriving your microphone or clipping the input signal from having the mic gain too loud. Experiment with mic gain settings, if turning down the gain gets you lower distortion you are overloading your inputs.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
Hi Ron,
Thanks for your response. You were right. I had the mic a little closer than normal to the speaker, and I didn't think to check this. What an idiot... Well I'm pleased the driver's distortion is nowhere near this level. Andrew. |
| Harmonic Distortion In Maggies | JimOfOakCreek | Planars & Exotics | 2 | 20th April 2008 04:04 AM |
| Why is distortion harmonic? | dsavitsk | Tubes / Valves | 48 | 12th March 2008 02:49 AM |
| What effect does a TL have on harmonic distortion? | owdi | Multi-Way | 0 | 26th April 2006 03:55 PM |
| second harmonic distortion | tenderland | Tubes / Valves | 5 | 5th August 2004 11:29 AM |
| Non Linear Distortion testing - Harmonic Distortion | JMB | Multi-Way | 0 | 20th July 2004 02:54 PM |
| Page generated in 0.08448 seconds (72.87% PHP - 27.13% MySQL) with 11 queries |
