Old 12th February 2007, 02:05 AM   #1
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
Default Dayton Reference RSS315HO-4 in ported box-help tuning
Hey guys I modeled the RSS315HO-4 in a ported box and it looks good in a 2 cubic foot box tuned to around 22-24hz range. It gets peaky at the top of its band, but crossed over below 100hz gives a very flat looking response. Since I won't use it above 60-80hz, I think this is a good way to go. However, a port that allows me to tune 24hz is 3" by 27" which is a bit long, and puts the air velocity a bit high. Going with 4" puts me at almost 50" of length. One Idea I had was to mount the port outside the box, have it bend from the bottom back of the box out around the back over the top and port out towards the front like that. I think I saw a commercial company doing something like that, and then having a box for the flared portion to sit in, so it looks more normal, I think they called it a turbo port or something.
Anyway, any other options that allows me to keep a normal ported box. I know I could go with a passive radiator design, but would rather not as I have no experience in tuning one of those. Thanks.
Old 12th February 2007, 02:18 AM   #2
Are you sire you have those lengths right? They seem way too long...
You can make a slot port and bend the port as much as you need. One bend should be enough. Heres a design that is 2.1 cubes tunes to 28. Just lengthen the port slightly as needed...
http://img11.imageshack.us/my.php?im...z27sqin8xp.png
Old 12th February 2007, 02:03 PM   #3
Yeah sorry, I realized I never mentioned that was for two ports.
For a single port its much shorter, but the air velocity is high enough I think chuffing will be audible.
Also, I have to look, but I think I can't fit a 4" port on the box I built. I have to see, but I checked again with the 4" port, and it actually doesn't look bad, barely audible chuffing I believe.
Help designing ported cabinet for dayton rss315ho saabracer23 Subwoofers 34 8th April 2008 09:52 AM
Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? wigginjs Multi-Way 6 3rd March 2008 08:56 PM
HT SQ ported tuning frequency kyaloz Subwoofers 20 6th October 2005 02:12 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Page generated in 0.07799 seconds (71.75% PHP - 28.25% MySQL) with 10 queries
