I was looking around in this forum and found this design of a JBL coupler and i was wondering if it was hard to design. Is the design very sensitive to the parameters of the woofer used? What kind of response am i looking at? Around half an octave above and below the tuning frequency? i may try this for a toy house sub...or maybe even for my car with an ascendant Audio assassin as I dont need it to play a big range of frequencies....here are the parameters.
http://www.ascendantaudio.com/assassin8specs.html
It says it is an "organ pipe" driven by a speaker. i would think that is a bad thing since organ pipe will only play one note.
one frequency will be very loud. then a peak an octave above, 2 octaves etc. it would be quite horrible as a speaker.
i can imagine it would sound kind of like what you hear when you listen through a tube.
I don't know what it takes to simulate that type.
William Cowan has plans and plots for three positive flare horn which may be more practical than working with JBL's transflex or scaling it - look for "Tapped Horns" (after Danley)
http://diy.cowanaudio.com/
