Old 12th February 2007, 04:14 PM   #11
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I won't argue with you regarding your calc of air speed
However I know that this driver in a 125 liter (cf ???) cabinet with a single 10 cm flared port (correction from one of my first posts 10 cm = 3.9") plays down to 25 Hz at high power without any port noise...... The guy who calculated this for me has uses such speakers.
However I will of course describe the listining result here soon
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 12th February 2007, 04:43 PM   #12
Puggie is offline Puggie  United Kingdom
A better option may be the reinforced plastic hose used for water and 'trash' pumps. its available in sizes from 2" to about 6" dia and is a thicker harder version of what you showed originally. a PVC flexible (quite stiff though) hose with a spiral wire reinforcement. I have considered using it before, but never had a need to. Try Hardware and industrial pump equipment sales.
http://www.machinemart.co.uk/shop/ra...valves-filters
click on the non existant image in the upper left corner of the main window to see what I'm talking about, I'm sure you can get larger than 3".
Old 12th February 2007, 04:48 PM   #13
Jan Dupont's Avatar
Thnks for the input, Puggie
I will also look for this kind of hose.
Old 13th February 2007, 10:51 PM   #14
Ron E is offline Ron E  United States
Ron E's Avatar
On second thought, I would just use a PR...or two.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
Old 13th February 2007, 11:40 PM   #15
AKN is online now AKN  Sweden
No snake oil
AKN's Avatar
Send a message via MSN to AKN
Hi ACD,
Although not your thread subject, i must agree that one 4" port is very little for your box size, tuning and power.
Simulation with one 15" JBL 2235H in 125L box, 25Hz tuning, one 4" port and 150W input.
/ Anders
Old 17th March 2007, 04:33 PM   #16
Jan Dupont's Avatar
I promissed to return
Got the complete speaker sets up and running (though at the moment using a passive crossover). So fare no problems with the ports using my AMCRON's DC300 Series II in bridge configuration, however I can imagine using higher power than 300W you just put your face in front of the ports and you don't have to shave
More information on www.audio-circuit.dk under my projects
Old 17th March 2007, 06:25 PM   #17
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default Can I just add....
....I've used a mitre saw to cut an angle through a pipe to mike a 90 deg turn. Or you could use elbow pieces. I just wanted to put this here to give others ideas.
Cheers mikee55
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 17th March 2007, 08:24 PM   #18
Jan Dupont's Avatar
On this first test run I did use 90 deg. elbow pieces
Old 27th March 2007, 02:15 PM   #19
OzMikeH is offline OzMikeH  Australia
Don't forget you can get 45 degree PVC bends.
There are some Wide radius bends available, these are for electrical conduit to make it easy to pull cables into buildings.. I have seen these in 100mm with a bend radius of about 400mm
These are usually very thick PVC becasue they are designed to be cast into concrete slabs
Old 27th March 2007, 03:53 PM   #20
Jan Dupont's Avatar
Thanks OzMikeH
L-shaped port for vented design runethechamp Multi-Way 3 27th May 2009 05:11 AM
T-line within vented cabinet? mantraxl Multi-Way 3 13th February 2008 03:53 AM
Good idea to close the port on a vented 8-inch 2-way ? brjoon1021 Multi-Way 6 10th December 2007 09:46 PM
vented cabinet testing with woofer tester jaya000 Subwoofers 1 17th November 2007 08:39 PM
Reflex port under the cabinet ?? gary f Multi-Way 21 26th October 2003 10:17 PM
Copyright ©1999-2013 diyAudio
