I have a couple of Kef B200's, ex Monitor Audio MA5's, and was wondering if I could put them to use in a subwoofer. Please excuse my lack of knowledge if this is a stupid thing to ask, but is this realistic, and does anybodu have any experience of this, and could perhaps suggest suitable designs? Thanks Stuart
Stuart Adamson |
#2 |
which version of the B200 was fitted to the 5? Some data for your drivers would help. I think there are 3 or 4 versions on this forum.
regards Andrew T. |
#3 |
Enjoy good sound
Hi spikey,
Not much x-max on those Kef but good parameters otherwise. There are several iterations of this woofer B-200-A,B,G etc, which is yours? With several units in a large box total displacement can be good anyway. How many units do you have? Can you tolerate a large box?
/ Anders |
#4 |
They're SP1014s, and I have 2 of them. I wouldn't be looking for lots of power, but I would like a clean sound if that helps.
Stuart Adamson |
#5 |
http://homepage.mac.com/planet10/TLS...200_SP1014.gif found in http://www.diyaudio.com/forums/showt...ht=#post731448 That 10Vrms for 96db is ~=85db/2.83Vac@1m. Xpp=6mm is Xmax=3mm. Q=.51 suggests sealed box. Don't apply any Linkwitz transform nor similar EQ to extend the low bass, you'll run out of travel at very low volumes. I did a search on sp1014 and found five other threads.
regards Andrew T. |
#6 |
Thanks Andrew T.
This is all new to me, and I don't yet fully appreciate what those specs mean. Are you saying that I wouldn't be able to get much deep bass out of these drivers, and therefore that they aren't the most suitable to use?
Stuart Adamson |
#7 |
input the driver data into a sealed box modelling program and look at what Q you end up with for different sized boxes. For lowish bass you need a big box, roughly equal to Vas in volume. This will not go loud but it might sound nice if you can disguise it as a coffee table or TV stand. You could try diysubwoofers.org and use their sealed box model. and read the two sets of design notes (general+sealed).
regards Andrew T. |
#8 |
Thanks for being so helpful Andrew.
Now I've got somewhere to start! The Subwoofer DIY page looks useful. Cheers
Stuart Adamson |
#9 |
So.....
Well I've done the numbers, and it's clear that to get a decent response from these drivers in a sealed box the enclosure size could lead to domestic difficulties. Looks like I'll knock that idea on the head and have a rethink - still that's something I've learnt today.
Stuart Adamson |
#10 | |
Hi spikey,
Andrew T wrote: Quote:
I dug up a TL I have made near a dozen of (1970-1980) since B200 could be purchased. It may be used as a closed box or TL and if used as a sub lower than about 120 Hz, you can place the driver/port almost anywhere on the baffle. b 1(2) |
| B200 Kef Drivers | Neopsp | Multi-Way | 108 | 8th April 2012 02:31 PM |
| wtb (1) Visaton b200 | nvrgdenuf | Swap Meet | 1 | 17th February 2010 03:46 PM |
| B200 competitors? | lazyfly | Full Range | 8 | 19th November 2008 03:44 PM |
| Visaton B200 in BIB | Rafal | Full Range | 5 | 23rd November 2006 07:40 AM |
| FS Visaton B200 | JohnnyBoy | Swap Meet | 3 | 24th October 2006 02:35 PM |
| Page generated in 0.10046 seconds (78.15% PHP - 21.85% MySQL) with 11 queries |
