8" Subwoofer cabinet schematics needed.
First of all i introduce myself since i'm new to the community, My name's Hernan i'm 19 and i love evrything related to audio, amplifiers, speakers, etc, i've built some things of my own and now i want to build a subwoofer with an old 8" speaker i have at home. The problem is i can't find any vented subwoofer cabinets for an 8" speaker. I want to build one similar to those 2.1 speaker system for computers but i can't find any schematics. Does anyone have an idea where i can find them? I'd apreaciate that a lot.
Thanks in advance.
AKN
Joined 2005
Hi hernanstafe and welcome!
First of all your box configuration is determined by woofer parameters, intended use and your sound preferences, hard, loud, soft, low etc.
No universal box for every woofer exists, at least not if you expect some quality sound.
I'll start with, do you have any specs such as Thiele-Small parameters for your woofer?
Alright...
Ok 4fun, thanks a lot for your reply! Now i'm gonna answer what you asked me:
About the woofer parameters, sadly i don't have them. I Can still send you a picture of the woofer (i'm don't think that'll help) since it was a very cheap speaker i bought ages ago and it doesn't come with any kind of technical specs. Actually, it's not a subwoofer it's just a woofer, but since i have it there doing anything and i got just 1, i'd like to try to do a sub anyways, even if it doesn't have the bestest sound.
Intended Use: Well i'm trying to do a multimedia speaker system for my computer, you know, a subwoofer and two satellites. It's of course for home use, to use with a computer to be precise (of course i'll also build an sub. amp too).
Sound preference: errr that's a tough question lol, it's difficult to explain with words. Of course i'd like to to sound loud, but also i want good hard bass, you know a good "punch" sound lol, i don't know if i'm being clear. I've heard some Edifier, Sony, Aiwa speaker systems for computers with subwoofer (tho they were 4" subs) and they all sounded nicely, so i want to do something similar to that (i'm assuming with a 8" speaker the bass can be even better).
So that's it for now, if you need something else please let me know, i'm sending you my email adress on pvt in case you need pictures of the speaker or something, you let me know.
Thanks a lot for your help.
Administrator
Joined 2004
Hi hernanstafe,
It's pretty hard to suggest what size of cabinet for you without the parameters but you can always just wing it if you have to. If I were guessing, I would start with about a 1 cu ft. cabinet, maybe 1.5 if there's room. Start with a test box, and you can adjust the internal volume by adding pieces of wood until you're happy. Then calculate the volume of box by subtracting your internal pieces.
BTW, this is the wrong way to do it but if you don't have any info on the driver, it's a guess and by golly. Maybe.
How loose is the supension in comparison with other drivers?
AKN
Joined 2005
hernanstafe,
If you are able to do what zlast suggested you have come a long way. Next step is some geometric measurements of the speaker then off to some simulation program.
Please do mail some pics. Got no mail from you, maybe you are not allowed to mail through the mail button yet?
Cal Weldon, that 1, or 1,5 cu ft cabinet is closed or vented? and how big is the vent? and the suspension is quite hard.
I might just try to calculate the thiele-small parameters like zlast told me to...like i said i'll TRY to do that lol!!
Thanks a lot guys!
Pd: 4fun! yeah i can't send pvt messages yet.
AKN
Joined 2005
Cal,
If the supension is very stiff, you may have a large Vas
Oh, it's the other way around.
Vas is the volume of air that has the same compliance as the speaker's suspension, so stiff suspension means less Vas.
hernanstafe,
Ok, saw the pics.
It looks like a driver for car use, open air type, those drivers usually have high Q less useful in a box unless it's very large.
I hope I am wrong.
Is it possible for you to do the measurements suggested?
The values you will get tells very much of your driver.
Well guys yes it's for car use. I'm gonna try and measure that stuff tho i'm not sure if it's gonna work hehe, i have an Aiwa amplifier and i think it's quite reliable tho it's not 10W like the page says it's 35W per channel. Can i still use it? Well i'm gonna try anyways, i'll let you know any news.
Again, thanks a lot to all of you! I apreciate your help a whole big lot.
PS: I'm going to post some pics of some loudspeakers i've built with 15" woofers and they sound awesome. I agree with cal "Big speakers are good" :smash:
AKN
Joined 2005
hernanstafe,
Yes!
If you read the instructions you'll notice that Rod suggest no more than 1V when measuring just to be sure that the driver not will be driven into nonlinear excursion areas, this he explains to. 1V is 1/4W into 4Ohm and 1/8W into 8Ohm.
Good luck with your measurements!
This is what i want
Ok guys look at this, this is exactly the kind of thing i want to build:
http://rapidshare.com/files/15132586/Subwoofer.rar.html
There you can see the subwoofer and the satellites. There are also a couple of pictures of the inside of the subwoofer. Apparently they used a TDA2030 amplifier, tho idk how they did to fix the huge distortion problem that IC has at high volume, any ideas? they also used a NE5532 but i' don't know what for, i'd to know if any of you knows that too. Then as you can see they used a vented enclosure for a 5" sub. These are the dimensions of it:
Dimensions:157(W)×235(H)×334(D)mm
Ok i hope you have a better idea of what i want to build now, i remind you that i want to do the same with a 8" car woofer (i think it's useless tho) or a 6" woofer i found at home (this one's suspension is much softer than the 8" one so i think it'd work better, i don't have thielle small for that one either).
Hope to hear from all of you soon!!
