Just built a new sub, and so far not impressed at all. Heres how it lays out
Adire Tumult 15" MK1 Dayton 500Watt Plate Amp BOX: Ported (nearly 5 ft long port) little over 5 cubic feet A friend designed the box and I just made it. So far im pretty unsatasified with the setup. It seams very weak. When I turn the gain up on the amp....it cuts out (led turns red and I have to cycle the power) Ive played with the EQ on it extensively, and the furthest I can have the Gain is at 50%. Is the amp shutting off because the woofer cant handle the load or becuase the amp can not take being up that high. This is the first sub I built so I am new to all this. Please let me know what to change if anything at all...... Thanks in advance Chris |
#2 |
Hello mioduz, I'm not an expert, but is your port really 5 foot in length?
I didn't know ports should be that long. I'm guessing that the cone is flapping? Maybe not, but 5 foot Whats it like with a rag shoved in the port, to temporarily close it?Cheers Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi |
#3 |
Did it Himself
What diameter is the port? 5 ft long is definitely many times too long no matter what diameter it is.
The amp is shutting down I suspect because you may be asking too much of it, or it's faulty. It's unlikely to be 500 real watts. That said, even 250 which it's likely to be is a lot of power for a large (efficient) box. Are you trying to fill a hall or something? Also bear in mind that if your source level is quite high you won't be able to have the gain up much. The gain dial is not a simple 'power' dial.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Welcome to diyAudio.com. I'd go with richie000boy, he knows loads more than me. He's helped me with my Linkwitz Transform sub, everything from measuring the driver's Thiele/Small parameters to cutting my box up and then he's helped with the electronics too.
But to be honest, everybody is here to help one another. I used to frequent the 'Audio Asylum', but these days, I like to reside here. So hello to you. Cheers Mike
#5 |
I would have went with the 1000 watt amp....and check that port out ...way too big...
Check all your connections. |
#6 |
diyAudio Moderator Emeritus
The Tulmut MK1 has dual voice coils of 4ohm each. They can be wired in parallel or series. If you've wired them in parallel you would have a 2ohm load on the amp and that may explain the problem your having with the amp cutting out on you.
Rodd Yamashita |
#7 |
Did it Himself
Also if the coils have been wired out of phase you would get very weak performance from the driver.
| Adire Tumult 15D2, box? amp? | whitetrash84 | Subwoofers | 2 | 24th May 2006 01:35 PM |
| Adire Audio Tumult | andytv | Subwoofers | 3 | 8th March 2005 01:15 AM |
| Horn loaded Adire Tumult | eRiCdWoNg | Multi-Way | 6 | 29th June 2004 08:59 PM |
| Adire Tumult discussion... | eRiCdWoNg | Multi-Way | 11 | 21st September 2003 06:11 PM |
| Page generated in 0.10177 seconds (69.22% PHP - 30.78% MySQL) with 10 queries |
