I am getting a new sub as an addition to my current 5.0 setup. My house is wired for 5.1 but only with speaker wires (with banana type connections).
Can I use the sub RCA pre-out from the amp to connect to the speaker connection, then connect the speaker wire back into the RCA amp on the sub? Do I need to worry about shielding on the cable causing interference, etc...? Thanks JT |
#2 |
Speakerholic
Does the woofer amp not have speaker level inputs?
EDIT: You can do it your way temporarily but I would go get an actual cable as soon as you can. |
| On/off LED wiring question | gary h | Tubes / Valves | 16 | 22nd June 2009 08:20 PM |
| DVC Wiring Question | 69stingray | Multi-Way | 3 | 6th April 2007 12:42 PM |
| Amp/Sub Wiring Question | OKCMustangGT | Car Audio | 3 | 31st August 2006 09:14 AM |
| Wiring question | LizardBrain | Multi-Way | 4 | 26th March 2006 03:46 PM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Page generated in 0.08181 seconds (69.10% PHP - 30.90% MySQL) with 10 queries |
