Old 28th January 2007, 09:29 PM   #1
Timn8ter's Avatar
Default New CSS SD12 Vented Subwoofer
Hi there.
I thought there might be some folks out there interested in this recent project of mine.
http://www.timn8er.com/cliff_subwoofer.htm
Old 29th January 2007, 07:25 PM   #2
Nice setup. Small footprint with a 12" driver. Did you install the BASH300 as is or did you modify the bass boost at all by changing the resistors?
Old 29th January 2007, 07:32 PM   #3
Timn8ter's Avatar
Thanks.
I left the amp stock.
Were I to do a sealed box a 4db boost at 25Hz would work nicely.
Old 29th January 2007, 08:44 PM   #4
Tim, I see that you had designed it to pair with the Emma. I am interested to know if you have tried it in conjunction with either the Ruby or the Rosa.
I also like the idea of the TB3 surrounds. They look just what I may be looking for. As you said it helps to have matched surrounds. What did you intend to match these with? The ELF1.5 you buddy has put them with?
Old 29th January 2007, 09:03 PM   #5
Timn8ter's Avatar
I played the Cliff with the Emma, Dakini (a.k.a. Adire DDR) and a little 2 way called the Myra-mini (WR125S and HiVi RT1.3).
I think this sub does better with a speaker that can play reasonably deep so the crossover point can be kept low. That would apply to pairing it with the Ruby as well.
A sealed version would probably be a better choice for crossing higher, IMO. Perhaps front firing as well.
The TB3 was my surround design for the Elf 1.5.
Old 29th January 2007, 10:26 PM   #6
Thanks. I was thinking it would probably work well with the Ruby. Very impressive work that you have done.
Old 31st January 2007, 05:33 PM   #7
CSS/XBL is offline CSS/XBL  Canada
Looks like a great design Tim; thanks a lot.
I've also posted the drawing for the sealed version I currently use myself. It's running with the A-400 with 6 dB of boost at 25 Hz.
I have the Reckhorn F-1 and B-1 on order and I think these represent cost effective and unique solutions.
We'll also be posting some other designs shortly and in about 2 months there will be another driver, the SDX15.
Bob
Old 31st January 2007, 06:55 PM   #8
Timn8ter's Avatar
Thanks Bob.
I tried to get my customer to go with the A-400 but no go.
I really wanted to check it out too.
Old 31st January 2007, 07:09 PM   #9
TerryO is offline TerryO  United States
TerryO's Avatar
Tim,
Nice job on the Sub! I also like the fact that you're using a Sansui amp in your system, i know I really like mine.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 31st January 2007, 08:02 PM   #10
Timn8ter's Avatar
Then you should really appreciate the fact that it was free!
It is a darn nice amp. My father-in-law bought it in Japan in the 70's (model AU-710 rather than 717) played it once and put it in storage.
Before he moved to Vegas he asked me if I wanted it.
DUH!!
Subwoofer for ROOM. Sealed or Vented? -_nando-_ Subwoofers 14 10th January 2006 07:29 AM
Aperiodic vented subwoofer(s) Jimmy154 Subwoofers 6 25th January 2004 09:57 PM
vented subwoofer vs room issues? Ilianh Subwoofers 8 14th December 2002 08:13 PM
Tempest vented EBS subwoofer BrianGT Subwoofers 35 25th October 2002 05:24 AM
Page generated in 0.09663 seconds (75.53% PHP - 24.47% MySQL) with 10 queries
