Old 24th January 2007, 08:09 PM   #1
braden is offline braden  Canada
Question PE 500S coupled with Hi-Vi SP10
Hello Everyone! =D
I'm interested in building a new subwoofer for my basement apartment. I was thinking of going with the Parts Express 500S Digital BASH plate amp combined with the SP10, since they have similar capacities.
One thing I am unsure of though, is the type of box I should house them in. My mate told me that a bandpass box was probably my best bet as they seem to maintain a constant low note. I purchased three full sheets of 3/4" plywood (not MDF) and am thinking about laminating two of the sheets together to form a 1 1/4" (because we all know 3/4" plywood isn't actually three quarters of an inch) piece of plywood that I can use to build a reletively large box out. But some rough dimensions and whatnot would be a great help.
Here are the links:
driver - http://www.partsexpress.com/pe/showd...number=297-460
amp - http://www.partsexpress.com/pe/showd...number=300-752
Any comments and suggestions are greatly appreciated.
Thank you in advance.
Braden.
Old 24th January 2007, 08:50 PM   #2
owdi is offline owdi  United States
owdi's Avatar
Any reason why you are limiting yourself to a 10" woofer? Can you give some more information about what enclosure size you are limited to. How big is your basement?
In general, I would not recommend a bandpass enclosure for 99% of applications. For a small room, a low Q (.5-.6) sealed subwoofer is a good first project. For a large room, a vented cabinet can be a good choice.
Here's a great place to get more info:
www.diysubwoofers.org
EDIT: For an apartment, a dipole subwoofer can be a good choice, because you can play it louder before you annoy the neighbors.
-Dan
Old 24th January 2007, 10:08 PM   #3
Thank you for your reply!
I wouldn't say I'm limiting myself to a 10", that was just a rough starting point. I would go to a 12" driver if I could find something that looks as burly as that Hi-Vi does. I'm not limiting my enclosure size either, I'll build it as big as I can to attain the frequencies I desire.
I'd like to keep it under four sheets of 3/4" plywood though. the sub would be used in a variety of rooms, ranging from about 12'x15' to about 20'x48'. So bandpass is out of the question then it seems like, I guess thats mainly a car type of box.
PS: my "neighbors" don't really matter. I live with all my friends. So loud music isn't really a concern, especially if its coming from my dungeon!
Thank you sirs!
braden
Old 24th January 2007, 11:45 PM   #4
owdi's Avatar
10" subs may look burly, but the low bass performance just isn't there against larger drivers in the same price range.
Instead of the HiVi SP10, consider the Dayton Refernce 12" HF in a 3 cu. ft. sealed enclosure.
If you have the space, the Dayton Reference 15" HF, in a 6 cu ft. sealed enclosure would be a step up.
When you build the box, try to make the front baffle as small as possible. Don't worry about getting the volume exactly 3 or 6 cubic feet. You could build the enclosure twice as large, and it would still sound good. Your choice of amp is good for both of the above woofers.
Dan
Old 26th January 2007, 07:37 AM   #5
Dan,
I thank you for your time and thoughtful reply. I will definately take those suggestions into account when I order my components.
12" MKIII
12" EMINENCE GENII
Just to throw a few more into the fray. If anyone has any comments on these units I'd like to hear
I am going to construct the box out of double-laminated 3/4" plywood. and for mounting the actual driver I was going to use grade 8 allen bolt hardware, and drill holes through the box and seal both the head and nut end with some type of silicone and using LocTight on the threads. I want this box to be as bomb-proof as possible. Since I know I'll never actually utilize all 500W (although knowing it's there is rather nice). When I do things, I like to do them right.
bradent
Old 26th January 2007, 03:16 PM   #6
I have been looking at the 15" Daytons mentioned above. ANy feedback from people who have used them? I am considering 2 of them.
Would the PE BASH500W be capable of driving both of them?
Old 4th February 2007, 06:16 PM   #7
keyser is offline keyser  Netherlands
I am interested in the hi-vi SP10 too. It goes pretty low in a very small box.
Does any of you know if this hi-vi woofer is used in any factory built subwoofer? It looks a lot like the one that's in the REL Q201. It also looks quite similar to the one in the Velodyne HGS 10.
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche
Cardioid-like + Waveguide 2-way
Old 6th February 2007, 05:55 AM   #8
so i've been talking to a few mates of mine, and i've been informed that i'm probably going to get burned @ customs when the package from parts express comes.
so i've been looking around on the net to find some canadian retailers that sell drivers and plate amps, and i'm not having much luck at all. i did find one guy out in BC who sells the exact amp i was looking @ and he sells a 12" subwoofer as well.
here is the link
css sd12
anyone from canada have any links they'd like to share?
Old 18th February 2007, 04:28 PM   #9
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
Default Canadian Suppliers
For diy audio solen is one of the most common canadian suppliers. There website is not as user friendly as parts express and I don't think they carry plate amps.
Creative Sound has the Bash Plate amp also. I haven't ordered from them yet but they have good products.
If you get a shipment through UPS you pay a noticable amount for them to take it through customs.
The worst I ever paid at delivery by UPS was about $59 cdn (~$200 american package) from parts express. Thats for customs, taxes ect.
Postal service is far cheaper in that way.
Old 19th February 2007, 03:32 PM   #10
solen,sells plate amps and the sp10.braden,when in ontario are you?
capacitor coupled vs. direct coupled ouput hugobross Solid State 11 21st January 2011 01:56 AM
Newb w/a Bash 500S needs sugg. on Sub & Enclosure deetz Subwoofers 6 12th October 2007 10:29 PM
rockford fosgate 500s mike49504 Car Audio 14 20th October 2006 06:04 PM
Need Help: RF 500S amp with tonns of DC in output valterdaw Car Audio 5 23rd June 2006 03:35 AM
Can someone explain parafeed & direct coupled & a.c. coupled? mwmitchell Tubes / Valves 2 11th September 2002 01:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
