Hey guys, i have an Polk MOMO subwoofer (4 ohsms) that i removed from my car is possible to use it in my house as subwoofer for my music and HT?
#2 |
Yes, but you should pair them with a power amp that can drive low ohms with high current. Most cheap modern HT amps won't do that well.
Do you have T/S specs?
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 |
Resonant Frequency 31 Hz
Qms 13.66 Qes .54 Qts .52 Vas 2.25 cu.ft. / 63.71 L Bl 14.2 Tesla Meters Sd 80.39 sq.in. / 518.6 sq.cm Xmax (linear) .37 in / 9.5 mm Xmax (mechanical) .75 in / 19 mm Le 2.42 mH |
#4 |
Hi
Thanks, Qts > 0.4 means closed or sealed enclosure. So WinISD program shows sealed box 70 liters with Qs = 0.71 and F-3 dB around 41 - 44 Hz So, should sound great for music, but not the best for action movie soundtracks. Regards,
#5 |
oh, ok, so need to found another driver
| Polk Audio MW8000 drivers pair | Rockmore | Swap Meet | 2 | 24th September 2009 05:48 PM |
| Polk Audio db1240 DVC for Home Sub | neeraj | Subwoofers | 4 | 17th June 2009 09:49 PM |
| Polk Audio RT-25i/CS245i/PSW250 system | john65b | Swap Meet | 0 | 27th July 2008 01:37 AM |
| Measurements of polk audio speakers | Ron E | Multi-Way | 0 | 25th February 2007 01:33 AM |
| Polk audio 10A crossover problem | argonrepublic | Multi-Way | 2 | 8th May 2005 06:41 PM |
| Page generated in 0.07412 seconds (69.33% PHP - 30.67% MySQL) with 10 queries |
