Hi all, can someone explain why the Linkwitz Transform doesn't use a lowpass filter? There is no mention on Rod Elliott's Project to use a crossover.
I'm just curious before I repair mine.I used a lowpass filter in-between mixer and L. Transform. Anybody else use it this way? Cheers mikee55
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi |
#2 |
A closed box speaker behaves as a 2nd order HP filter at low frequencies.
You might think of the Linkwitz Transform as a "thing" that first makes the FR flat and then makes a new 2nd order HP filter at (almost) any frequency and Q. A LP filter (+Linkwitz Transform) can sometimes be a good idea to avoid breaking the woofer because of high excursion but maybe it is better to adjust the Linkwitz Transform for safe operation. D |
| Linkwitz Transform PCB help | mikee55 | Subwoofers | 2 | 3rd October 2006 09:36 AM |
| Linkwitz Transform PCB? | diydave | Parts | 2 | 1st September 2005 12:05 AM |
| question about Linkwitz transform | shaunly | Parts | 6 | 14th November 2004 07:34 AM |
| Linkwitz Transform? | Aunkst | Chip Amps | 6 | 28th March 2004 11:59 PM |
| Which op-amp for linkwitz transform? | Hybrid fourdoor | Multi-Way | 2 | 13th September 2003 12:22 PM |
| Page generated in 0.07278 seconds (69.00% PHP - 31.00% MySQL) with 10 queries |
