Old 19th January 2007, 07:15 AM   #1
Default I need to lowering Qms of the driver, using Resistive braking - one coil shorted
Hi all,
I have a driver with dual voice coil.
I made a T/S param measure using this methode:
http://sound.westhost.com/tsp.htm
With voice coil in parallel (4+4=8ohm) I got the result, also with single voice coil (4ohm) and second voice coil left open,
but when I shorted the second voice coil, I couldn't get the result,
there was no voltage drop across the resistor to measure Fs, it just at the same level at all frequencies...what was wrong?
I need to lowering Qms of the driver, since it very high, using Resistive braking - one coil shorted as per this article:
"When you run a single voice coil, it has the nominal single-coil Qes of 0.8.
So, with the second coil open, you'd have a Qes of 0.8, and a Qms (unchanged) of 6.5, for a Qts of ~0.7.
Now, when you short the second (unused) coil, it essentially acts as an electric brake.
This will manifest itself by lowering the Qms to the Qes of a single coil: 0.8.
So, you'll have a driver Qes (of the coil you're driving) of 0.8, and a Qms (of the shorted coil) of 0.8, for a combined Qts of ~0.4.
One coil driven, other open, Qts = ~0.7. One coil driven, other shorted, Qts = ~0.4.
Dan Wiggins
President Avatar Audio"
taken from:
http://www.users.bigpond.com/bcollis...onversions.htm
is it wrong to measure single VC with second VC shorted? Should I use the result form single VC with second VC left open and using the theory above to get new Qms value?
thankyou,
Chris.
Old 19th January 2007, 08:40 PM   #2
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
Hi christophorus,
Do you have any specific reasons for lowering just Qms?
High Qms is a sign of a low loss suspension.
If a manufacturers focus on terminating standing waves in cone a high loss surround is going to "eat" that energy and translate it to heat. Problem is that even wanted energy will be "eaten" to some degree. My personal opinion is that low Qms speakers will sound lifeless especially at low levels.
/ Anders
Old 20th January 2007, 02:56 AM   #3
Hi Anders,
thank's for your reply, I need lower Qms because it seems too high, here my T/S param result:
#1-With dual voice coil in parallel (4+4=8ohm):
Fs=37,46Hz
Re=6 ohm
Qms=4,06
Qes=1,63
Qts=1,16
#2-With single voice coil (4ohm) and second VC left open:
Fs=35,36Hz
Re=3 ohm
Qms=10,33
Qes=8,28
Qts=4,69
first question:
is it normal Qts result from dual VC in parallel (#1) very different with single VC result (#2)?
second question:
with second VC shorted, it can not be tested for T/S param?
So to get it, I have to use #2 result and change Qms=Qes=8,28 and new Qts become 4,14.
Chris.
Old 20th January 2007, 08:27 AM   #4
Enjoy good sound
AKN's Avatar
Fs=37,46Hz
Re=6 ohm
Qms=4,06
Qes=1,63
Qts=1,16
Maybe you just typed wrong, two paralleled 4Ohm coils makes 2Ohm.
Your Re indicates series connection if each coil has 4Ohm impedance.
I would say that your Qms is fine but instead Qes is way off. Shure about the correct phase to coils?
What woofer are you measuring?
/ Anders
Old 21st January 2007, 12:38 AM   #5
Ron E is offline Ron E  United States
Ron E's Avatar
I think your measurements are questionable.
It can be difficult to measure T/S parameters when one coil is shorted because the impedance gets so flat. I think you should measure T/S in series and parallel configurations and if Fs, Qts,Qes,Qms aren''t much the same you have made a mistake.
Assuming they are the same. use the RDO calculation in the article you have to calculate the parameters with a shorted coil.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 21st January 2007, 09:03 PM   #6
Svante is offline Svante  Sweden
Svante's Avatar
You don't say how you go about to measure the T/S parameters. If you use an automatic computer program, it might be that it fails to measure the Q values correctly due to the flatness of the impedance curve.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 22nd January 2007, 08:30 AM   #7
Hi Anders,
you're right, it's series.
Hi Ron E,
so it must be measured in parallel or series, how about measure using one coil and the other coil left open?
And the important thing is: which ever measuring methode (parallel or series or 1 coil), the result should be not much different, right?
Hi Svante,
I did T/S param measure using digital multimeter, see my first post above.
Chris.
Old 22nd January 2007, 08:53 AM   #8
Did it Himself
richie00boy's Avatar
I think you either measured something wrong, or you have a cheap nasty drive unit.
If you can wait until this evening UK time I can post up my measurement technique which is helpful when you have drivers with small/broad impedance peaks.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 22nd January 2007, 07:12 PM   #9
Enjoy good sound
AKN's Avatar
This method is less sensitive to measurement accuracy, Rod also rightfully warns that his proposed method is sensitive to input errors, especially high Q drivers.
Regarding your multimeter and generator.
When no speaker connected, do you have same voltage reading at different frequencies, let say one octave above speaker fs, fs and one octave below fs of driver?
I'll ask once again, are you willing to share what driver you are testing or at least a picture of the driver?
/ Anders
Old 27th January 2007, 07:29 AM   #10
Hi Richie,
here is picture of my driver, doesn't look too nasty, does it?
Anyway, I'm still waiting your measurement technique, as your promise.
Hi Anders,
When no speaker connected, it has almost the same voltage reading at different frequencies.
Picture #2 is a close up of the driver, as you can see, between spider and chassis, it has a gap (covered with perforated steel grille), how if I sealed it off so no air can in / out from there, can it reduce the Qms?
Chris
Is there any hope for a driver with a rubbing 39mm voice coil? kappa546 Multi-Way 10 7th May 2009 09:38 PM
DC supply for Jensen A12 field coil driver korneluk Full Range 1 21st March 2008 07:23 PM
Newby's question about dual coil driver with plate amp minye Subwoofers 6 6th September 2007 08:13 AM
what tradeoffs by lowering driver impedanse with resistor? elviukai Multi-Way 18 9th July 2006 09:26 PM
Connect cable to driver, don’t sizzle voice coil? rick57 Multi-Way 3 18th February 2005 08:52 AM
Page generated in 0.13688 seconds (76.59% PHP - 23.41% MySQL) with 11 queries
