Any thoughts on these mysterious OEM 8" woofers? - diyAudio
Old 15th January 2007, 10:31 PM   #1
Send a message via AIM to Spasticteapot
Default Any thoughts on these mysterious OEM 8" woofers?
I saw these on Fleabay, and wanted your opinion before wasting my money.
http://cgi.ebay.com/OEM-8-DIY-DUAL-8...QQcmdZViewItem
They have a reasonably impressive looking magnet structure - otherwise, I have no idea.
Old 16th January 2007, 06:33 AM   #2
Volenti is offline Volenti  Australia
They don't look too bad, I wouldn't try to use them as subs, but in a ~50hz-200hz woofer role they should be satisfactory.
Old 20th January 2007, 03:50 AM   #3
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
Looks ok off hand. you should model it in winisd and give us an idea of your intended application, like box size, if your looking to use them a sub or low end of a 3 way ect.
Old 20th January 2007, 03:52 AM   #4
I was actually hoping to use them for exactly that. Problem is, though, that the mid-woofers I've got are good down to 50hz already.
Old 21st January 2007, 12:25 AM   #5
For low end these are better vented vs sealed but as noted above have little capabilites below 50Hz. Vented at 38Hz in .9cu ft gets a F3 of ~50.5Hz.
FYI those are shielded drivers so a large part under that cover is going to be a bucking magnet and not really part of the motor structure. For an idea of the exterior size of a sheilded vs unshielded version look at the 295-305 and 295-306 models from parts express
Parts Express
Initial Thoughts for "Mr. Piggy" SE Amp w/Screen Driven 6P45S wrenchone Tubes / Valves 10 24th September 2015 05:22 PM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
Sonus Faber 6.5" woofers and cheap 3" fullrange and misc. Jimmy154 Swap Meet 10 26th December 2007 04:20 AM
Thoughts on this Tang-Bang 6.5" "sub" eRiCdWoNg Multi-Way 23 20th March 2005 07:57 AM
Krell's "Sustained Plateau" Design - some thoughts bear Solid State 19 1st November 2004 07:24 PM
Copyright 1999-2017 diyAudio
