Old 11th January 2007, 10:28 PM   #1
qguy is offline qguy  Canada
Send a message via AIM to qguy Send a message via MSN to qguy Send a message via Yahoo to qguy
Default Boosting 25-30 hz
Hi how can I boost these frequencies ? (25-30hz)
I was thinking of modifying a graphic equalizer (which I have lying around somewhere) with bands from 50 to 15,000 hz. I reckon i can changed some capacitors / resistors ?
na
Old 12th January 2007, 12:39 PM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
If you are using a plate amp you normally can change the boost frequency and level by 2 resistor changes. Finding those instructions in another matter
No longer DIY active
Old 13th January 2007, 02:10 AM   #3
hifiger is offline hifiger  Canada
Send a message via MSN to hifiger
If you did all the math correctly then what you were thinking of would work in theory..
Just seems like a lot of work when you can go out and buy a BFD...
boosting frequencies from 45-65hz qguy Multi-Way 11 8th November 2006 11:02 PM
Signal boosting spots25 Digital Source 3 6th January 2006 01:18 PM
Boosting wireless home phone range/antenna ->5.8ghz JinMTVT Everything Else 5 22nd October 2005 02:56 PM
boosting a boost.. ChesterFuzzin' Multi-Way 1 22nd August 2002 08:20 AM
Page generated in 0.07965 seconds (71.58% PHP - 28.42% MySQL) with 10 queries
