Best TL Sub Design You Have Seen? - Page 2 - diyAudio
Old 20th January 2007, 07:46 PM   #11
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
2(5)
Old 20th January 2007, 07:48 PM   #12
3(5)
Old 20th January 2007, 07:50 PM   #13
4(5)
Old 20th January 2007, 07:54 PM   #14
5(5)
Old 21st January 2007, 02:28 AM   #15
Default acoustic coupler...
this design is I believe by JBL after the fashion of the Jensen Transflex but 1/4 wave. also see the patent by Arnold I Klayman US # 5, 177, 329. Both these designs are essentially what is today Known as Tom Danley's TAP Horn.
moray james
Old 23rd January 2007, 07:45 AM   #16
DorinD is offline DorinD  Romania
DorinD's Avatar
Do you see that the total TL lenght of the Transflex is 1/4 lambda but Klayman's total leght of the line is 1/2 lambda?!
So, the Transflex is essentialy a lambda/4 line with the open end at the same position as the closed one. And Klayman design could be seen as a pair of coupled lambda/4 lines or as a lambda/2 line excited by a driver on the pressure nodes.
In this case the Transflex is a relatively "large" bandwidth device as compared to Klayman's "uni-tone". How could be tempered these conflicting theories which give us the same construction layout but 2:1 dimensional ratio?!
Old 23rd January 2007, 11:55 AM   #17
DorinD's Avatar
Sorry, I re-read the Klayman patent carefuly and it is conform whith Jensen's Transflex. So, not the Klayman is suspicious but JBL design. There, that lambda/4 cote should be a lambda/8.
Old 23rd January 2007, 08:51 PM   #18
Can someone design a TL for that MJ 18? Im having a hard time interpreting those graphs
Old 27th January 2007, 01:30 AM   #19
GM is offline GM  United States
GM's Avatar
Greets!
Website? Specs?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th January 2007, 01:40 AM   #20
Fast1one,
I simulated a very simple TL 3 dB at 25 Hz that in most cases must be equalised if room gain is high and at an input power between 200-300 W a HP 12 dB/octave filter at 20 Hz should be included with the sub amplifier.
Note the slight improvement of group delay when using the defectors marked (b) and if the length of the enclosure is increased with + 10 inches, f 3 dB reaches 20 Hz.
b
1(4)
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 06:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 03:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 03:56 PM
Copyright 1999-2017 diyAudio
