Folding a Bass Horn
Folding a Bass Horn
Old 12th February 2007, 06:53 AM   #11
pederkruse is offline pederkruse  Denmark
Good idea to make it possible to distinguish the different labfractions. I shall look into it & Yes. When the centreline turns grey, you have reached the throat.
I don't remember if I sent you the little helpfile for the program. If not, you can get it here: http://nautrup.com/cahd/afewwords.htm
My memory was better in the past - I think
Old 12th February 2007, 08:23 PM   #12
shr-t is offline shr-t  Finland
Another thing, I would like to manually alter the measures of the horn (make it thinner and longer), because this gives a better spl response in hornresp and also makes the horn smaller in size.
Old 17th February 2007, 12:53 PM   #13
Default CahD update
I have added parting lines to indicate where labyrinth_circles end. I changed integer parameter "Horn splits" into a floatingpoint general "Area factor" and added a general "Length factor".
If you intend to split up the horn in two, you simply set "Area factor" = 0,5. If you want to get a standard one_labyrinth horn, true to the equations, just keep both factors as 1,0.
Folding a Bass HornHide this!Advertise here!
HORN FOLDING Questions... screamersusa Subwoofers 4 17th November 2008 10:43 AM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
building a folding horn for the time offroadbum Multi-Way 7 16th September 2004 09:26 PM
Horn Folding Advice? bigmike216 Multi-Way 22 21st August 2004 10:41 AM
Concrete tube molds and horn folding Thatch_Ear Multi-Way 0 29th May 2002 09:54 PM
