PE BASH 500W Plate Amp
I just recently bought another PE bash amp over the holidays and noticed the new amp was a little different. They may have changed the resisters to something more appropriate for the amps usage, but the older ones did indeed have the 30hz filter. Ill take a look at the new amp to see if they did change the resister values. Either way its an easy change.
