AGC is used in subwoofer for limiter!
Old 31st December 2006, 01:26 PM   #1
GPE is offline GPE  China
Default AGC is used in subwoofer for limiter!
I would like to seek a kind of AGC circuit to limit output singnal so that distortion is low when input singnal is excess.
The output amplifier should be keeped max 200w.
Input sensitivity : input singnal 500mv ,output 200w!
Who can supply me AGC-LIMITER schematic?
Old 31st December 2006, 01:48 PM   #2
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
http://sound.westhost.com/project53.htm
Old 31st December 2006, 02:15 PM   #3
Default seek
If there are other way to meet the function!
I think that the assembly process is difficulty.
Thanks!
Old 1st January 2007, 06:18 AM   #4
Default nobady?
I have tried to do the AGC-limit with IC-LM13700!
But the distortion will increase to 2%.
The Driver will feel be worse!
Who can help to make the AGC perform well with LM13700 or Mosfet.
Old 1st January 2007, 10:54 AM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Default Re: nobady?
The distortion will increase, because the the limiter is changing, (distorting), the input signal in a non linear fashion. It's what it does, any compression or limiting will do the same.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 3rd January 2007, 04:47 PM   #6
ChocoHolic is offline ChocoHolic  Germany
How about posting the schematic of the circuit, which you have tried....
In general I would propose an unsymmetric time behaviour for the acting characteristic.
If the input signal is to large then the gain must be reduced fast and limit the output voltage to a certain level.
Moving back towards higher gain must be slow. Slow compared to the normal bass pulse sequence of your music programm.
So the limiter will pull down the gain during the first waves of the drum and then 'remember' the right gain for the next beats...
But you will always have some influence of the 'changing/pumping gain' on the output signal.
Old 3rd January 2007, 04:52 PM   #7
Add on:
'If the input signal is to large...' is misleading.
The relevant control criteria for the regulation loop is the output.
Just from outside it will look like high gain for low input signals and dropping gain above a a certain input level.
Old 7th January 2007, 01:29 PM   #8
micb is offline micb  United Kingdom
Default Re: AGC is used in subwoofer for limiter!
Why do you want this limiter in place?
I can't help think there is a reasion why you are wanting one that may be solved another way.
AGC is used in subwoofer for limiter!Hide this!Advertise here!
Compressor / Limiter whoandcar Solid State 6 12th May 2008 03:50 AM
Power Amp limiter yugaaa Car Audio 8 1st August 2006 09:37 AM
Do you think this is a limiter? destroyer X Solid State 7 11th December 2004 11:26 PM
Limiter with SA 571 hanzs Solid State 0 4th October 2002 04:46 PM
Copyright ©1999-2017 diyAudio
