Old 30th December 2006, 04:38 PM   #1
Default Bandpass Filter on a Subwoofer
Hello, This is my first post in the Subwoofer forum!
I ran into an unbelievable deal on a pair of Magneplanar SMGs a few days ago, with the Maggies, I got two 8-inch passive subwoofers for use with the SMGs to take some of the bass load away from them. The subs were homade in gorgeous boxes (ones that I could never personaly construct). The reason I am posting is because I found something perplexing in the crossover.
The two sets of terminals (one for in, and one for out) have the two red nodes shorted by a capacitor, this makes perfect sense to me, as It acts as a high pass filter to keep some of the bass frequencies from getting to the SMGs. Then the signal line going to the sub goes through and inductor, this would make a low-pass filter (once again something I completly understand). After this inductor, the wire then goes through a capacitor before going into the woofer, making the inductor, and the capacitor together a bandpass filter. Is this a common practice in subwoofers? is there any need for a low-end roll off in a subwoofer?
In any event, I guess what sounds the best is the most important thing, so I may try shunting the second capacitor to ground (making it another low-pass filter), and see how that sounds.
Thanks alot, any comments would be greatly appreciated\
-Moose
Old 30th December 2006, 06:34 PM   #2
pinkmouse's Avatar
It's possibly a high pass filter to protect the drivers from over excursion at low frequencies. In that case, bypassing would be a bad idea.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 30th December 2006, 07:10 PM   #3
Speakerholic
Cal Weldon's Avatar
What size is the cap?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 31st December 2006, 01:54 AM   #4
:xrow: is offline :xrow:  United States
Many car audio amps have a built in subsonic filter to block the really low frequencies (set usually around 15-25 hz). It is there to prevent the sub from bottoming out at high volumes in ported enclosures.
Old 31st December 2006, 04:05 AM   #5
all of these explainations make sense to me, i'll look at the cap once I return home tomorrow afternoon, and run it through the equation to see where the 6db point is
WinISD pro to simulate 6th order bandpass subwoofer christophorus Subwoofers 14 13th September 2006 12:58 PM
design of microwave bandpass filter help!! pr2don Solid State 0 3rd August 2006 02:22 PM
6th order bandpass subwoofer Ilianh Subwoofers 50 25th January 2003 01:40 AM
bandpass subwoofer Opie Subwoofers 4 14th December 2002 10:12 PM
bandpass subwoofer ogp Subwoofers 1 28th September 2001 11:05 PM
Page generated in 0.08773 seconds (70.75% PHP - 29.25% MySQL) with 10 queries
