Old 29th December 2006, 09:48 AM   #1
Default variable phase 0-180 deg.
I want to integrate my famous janis subwoofer to my system. I don't have the interphase-1 that belonged to it. So I'm constructing a active filter ( from the group buy). A third order filter at 100hz is required. That shouldn't be to difficult.
A variable phase 0-180 deg. is also highly recommended. So i thought a all-pass section should do the trick.
I'm confused about the math, if half the wafelength of 100hz is 6,8meter. With an allpass section i can compensate only for several tens' of centimeter.
please help
Old 30th December 2006, 05:41 PM   #2
Default oeps
Oeps, half the wavelenght of 100 Hz is 1,7 meter.
Old 30th December 2006, 06:37 PM   #3
RobWells's Avatar
Any use to you?
http://sound.westhost.com/project103.htm
Rob
btw - this link comes up as the second result when you google 'subwoofer phase control' You did search didn't you?
Old 31st December 2006, 01:14 AM   #4
I did search, but with tunnel vision and wrong preconceptions.
Thanks for the link. It has several considerations i had not thought about.
It leaves me with some rethinking en studying.
Circuit for variable phase 0-180 control for active L/R xover georgehifi Solid State 4 20th September 2006 09:55 AM
Subwoofer variable phase control AudioFreak Solid State 23 18th July 2004 03:54 PM
dipole sub H-Frame, phase or opposite phase ? mbon Multi-Way 6 19th June 2004 08:36 PM
Variable phase subwoofer palesha Solid State 5 23rd October 2002 08:16 AM
Variable phase circuit for sub ergo Subwoofers 1 29th August 2001 12:06 PM
Page generated in 0.06009 seconds (80.18% PHP - 19.82% MySQL) with 10 queries
