Old 26th December 2006, 02:24 PM   #1
Default 2 Subs 1 Plate Amp
Hi guys,
I just got this amp:
http://www.partsexpress.com/pe/showd...number=300-804
and this sub:
http://www.partsexpress.com/pe/pshow...TOKEN=81303062
I have a pair of Zaph's B3S speakers and want to integrate them with this sub. I was thinking that to avoid localization I could use two subs.
So the question is, could I buy another one of the Dayton drivers and enclose it in a seperate box but power both subs with my single plate amp.
If it is possible, what is the best way to wire it?
Thanks for the advice.
~Nathaniel
Old 26th December 2006, 05:54 PM   #2
kyselym is offline kyselym  Czech Republic
I would make it series to have 8ohm overal impedance it is only possible way unless you change amplifier. if you have amp to handle 2Ohms go for all parallel.
Old 26th December 2006, 09:16 PM   #3
owdi is offline owdi  United States
owdi's Avatar
Wire the dual voice coils in series on each sub, then wire the subs to the plate amp in parallel.
Dan
Old 26th December 2006, 11:51 PM   #4
Please pardon my ignorance, but could someone explain what the above post means. I understand how to wire light bulbs in series vs. parallel because I did it in high school but I'm not sure how to do it with the DVC.
Edit - Should it look like the attached picture but with two drivers?
Old 27th December 2006, 10:02 AM   #5
the picture you posted describes what owdi wrote. I wouldn't do that this way because all parameters for speaker are measured with voice coils(on one driver-mean speaker) wired parallel. I advice you to do it as well. This means that every speaker will have 4ohm impedance(because each voice coil has 8ohm impedance). Than you wire those two in series.
if you still don't understand: imagine one driver(speaker) as two rezistors(each has 8ohm resitance). in your case you have two drivers so you have 4 rezistors(each 8ohm). So wire two and two in parallel(those on one driver). now you have two (imaginary) resistors. now wire them series. thats all, hope you got it
Old 27th December 2006, 10:26 AM   #6
the dual Voice Coil drivers work just as well when the VCs are in series as when they are in parallel.
The difference is whether the amplifier can drive them properly.
All solid state amplifiers work better into the higher impedance load.
If you wire the VCs in parallel, the dual 8 ohm becomes 4ohm and two of these in parallel gives a 2ohm load on the amp. Not many amps are any good into a low load like this.
If you wire the coils in series and then the drivers in parallel you end up with an 8ohm load.
or
wire the VCs in parallel and the drivers in series and again you end up with an 8ohm load.
Both these wiring alternatives will work equally well when the drivers and speakers are identical, but I prefer the parallel speakers option so that each driver sees the low impedance drive from the amplifier. So series the VCs and parallel the drivers.
Best option:- buy a second amp and use a dedicated amp to each driver. Or even better 4 amps, each dedicated to an 8ohm voice coil.
regards Andrew T.
Old 27th December 2006, 11:35 AM   #7
hmm,
So is my idea even worth it or should I just build my single sub and then build another with its own amp later on?
How will doing this dual sub one amp setup change the efficiency / sound quality as compared to one sub / amplifier?
Thank you,
~Nathaniel
Old 28th December 2006, 03:15 AM   #8
owdi's Avatar
Your idea is fine. I suggested series voice coils and parallel speakers because it will be easier when the speakers are far apart. If you wire the VCs in parallel and speakers in series, you have to run a wire from one speaker to the other.
Dan
Old 29th December 2006, 03:39 PM   #9
Andersonix's Avatar
Default variable phase adjustment?
Not to add to your buyer's remorse, but why didn't you choose this plate amp instead?
http://www.partsexpress.com/pe/showd...number=300-796
Same price, same power, better S/N, and most importantly, variable phase control. This adjustment, although not perfect, can make an audible difference for fine-tuning and matching the sub with the satellites. A simple 0-180 phase reversal switch just isn't enough any more.
Old 29th December 2006, 04:27 PM   #10
I guess the real answer is that I didn't ask here first
I just wanted something quick and dirty to go with the B3S speakers. Within a year I will change this system into 5.1 for HT duty and start to build a better music system (thinking about Zaph's BAMTMs )
I am quite new to this whole DIY thing and this setup is more of a learning experience than anything
~Nathaniel
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 08:57 PM
ECC83 - Long Plate vs Short Plate poynton Tubes / Valves 16 17th February 2008 07:42 AM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 07:40 AM
Page generated in 0.11353 seconds (78.36% PHP - 21.64% MySQL) with 11 queries
