Old 22nd December 2006, 11:15 PM   #1
punkrokr1701's Avatar
Send a message via AIM to punkrokr1701 Send a message via MSN to punkrokr1701 Send a message via Yahoo to punkrokr1701
Default DVC subwoofers
How would wiring a SVC subwoofer in any way effect it's performance? I am refering to the Mach 5 10" sub which is DVC with 4ohm+4ohm voice coils yet the amp I am planning the use with it puts out 300 watts rms @ 4 ohm and only 170 @8 ohm is there any way to get around that by just using one of the voice coils?
Old 23rd December 2006, 10:34 AM   #2
95Honda is offline 95Honda  Germany
You can drive one coil. Power handling (thermal) will suffer, it will NOT be cut in half though as some may try and tell you. You will have a change in the drivers electrical Q also, but you can use/exploit this by either shorting or putting a variable resistance on the un-driven coil. You could have a driver with a variable Q.
Or just run the coils in series and see how you like it....
www.forceaudio.com
Old 24th December 2006, 05:12 AM   #3
paulspencer's Avatar
I wouldn't do that. You give up half of the BL that way. The only situation I can think of where that would be a good idea is perhaps with dipole use where the higher Qts would be desirable, and where little power handling is required.
Instead, I suggest either accept the limited power, or use a different amp, such as a 2 channel power amp that can be bridged into an 8 ohm load. The behringer A500 will put out 500w bridged mono into 8 ohms, more than you need.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
subwoofers j9184p Subwoofers 1 12th July 2006 02:45 AM
Subwoofers BEAN27 Subwoofers 5 23rd April 2006 09:09 PM
Subwoofers Chawk Car Audio 25 28th November 2005 09:04 PM
Car Subwoofers? maxdeaf Subwoofers 9 17th September 2003 10:48 PM
Page generated in 0.08266 seconds (70.66% PHP - 29.34% MySQL) with 10 queries
