Old 19th December 2006, 11:07 PM   #1
Klimon is offline Klimon  Belgium
Default Random 12" woofer in 100 liter cabinet
I'm aware of the invention of TS parameters and advanced simulation software.... but:
What can I expect from a 12" woofer (removed from Marantz 7g imperial speakers) in a 100 liter (=25 gallons) closed cabinet? Any rough guesses about low-end response and flatness of FR in f3-100hz region? I read that the original cabs were BR tuned at 80hz with about 60 liter (15gallons) internal volume. With some stuffing I could probably reach about 130l with my cabinets.
I have the 100l cabs lying around so it would be easy if they match up well with the 12" marantz drivers....
Would be nice to get a (rough) idea what to expect, there's still some work to do on the cabinets.
Thanks!!
Simon
Old 19th December 2006, 11:58 PM   #2
hifiger is offline hifiger  Canada
Send a message via MSN to hifiger
The xmax and the fs of the driver would help.
here is a quick response plot i made with unibox for a 12 inch driver with 10mm of xmax, fs of 30hz, Re 4ohm svc, Le 1.3mh, with 100watts in a 100L, heavily stuffed enclosure:
http://img219.imageshack.us/img219/5...esponsekx6.gif
Old 20th December 2006, 10:06 AM   #3
Thanks, that gives a rough idea. I would have thought a woofer that size in a cabinet that size would be about flat untill 40hz.... We'll see how it goes.
Simon
Old 20th December 2006, 01:51 PM   #4
Drivers designed to work in 60L reflexed are not going to work in 100L
sealed. Its a 12" so 100L doesn't sound too far off but I think you will
have to reflex it, I'd say at 35 Hz to 45Hz.
/sreten.
Old 20th December 2006, 03:16 PM   #5
tinitus is offline tinitus  Europe
I guess you will get more like -12db at 40hz, if you are lucky, and that could very well be the same with BR
They might be designed to be placed in corners or against the wall
When is a liter not a liter? The shape of things to come. brucegseidner Full Range 2 27th June 2009 02:35 AM
my new cabinet for two 8" woofer denbo123 Multi-Way 8 14th May 2009 01:52 AM
8'' woofer for 20 litre cabinet fin1bxn Multi-Way 5 17th April 2007 04:05 PM
woofer in 11 liter (0.38 cu ft) rwagter Multi-Way 3 4th May 2004 08:12 PM
Page generated in 0.08890 seconds (72.75% PHP - 27.25% MySQL) with 10 queries
