okay,
please tell me if this is a correct subwoofer / enclousure / amp setup. I am looking at doing this for an LFE channel in a home theatre. I will be using a Dayton 285-190 15" subwoofer along with a bash 500W amp. I am hoping to build a down firing box with a total inside volume of 275 liters. It will be a vented style with 4 2" port tubes on the front pointing towards the viewing audience. If i used the WinISD correctly, it gives me a sensitivity of 91db@1w@1m. does that sound correct? is this a feasible sub? Being that it is going into an opened cove in my basement, it will not be against any walls, probably about 3 feet from the back wall, and have a left and right channel about 2 feet from either edge of it. The center channel will be about 18" above the top of the subwoofer as well. will this work for sound imaging? |
#2 |
A smaller number of larger ports will work much better. Those 2inchers will be noisy as all get out....
Have a look at how a pair of 4 inch ports model. If you use WinISD pro, you can look at the port velocity vs frequency graph. For 4 inch ports with velocities above 6 m/sec you will need flares. The PSP Precision ports are good for about 14 to 16 m/sec.
Ports rule! |
#3 |
so looking at the adire tempist 15" sub I am thinking about doing a sonotube. It says I would need 2 4" tubes, the port length would be 16" does that sound right?
if I wanted to do a sonotube, what size sonotube would everybody recommend? |
| correct box? | dallaire | Multi-Way | 2 | 31st December 2007 07:25 PM |
| Easiest way to correct this dip? | JCoffey | Multi-Way | 12 | 11th June 2007 12:52 PM |
| is this PSU correct? | zafira1981 | Chip Amps | 15 | 18th November 2005 10:33 PM |
| My PCB for DoZ, it correct? | mod_evil | Solid State | 4 | 4th October 2005 01:30 PM |
| Correct Ampilier for subwoofer | alan85 | Subwoofers | 1 | 16th February 2005 08:39 AM |
| Page generated in 0.07615 seconds (83.02% PHP - 16.98% MySQL) with 10 queries |
