Old 4th December 2006, 11:07 PM   #1
Default MJK TL Sub Help Needed
Hello,
I need help designing an MJK based TL subwoofer. I have looked at the stuff located on Martins website and still can't understand how to come up with dimensions,stuffing or whether the TL should be folded or tapered. The driver I plan to use is the Dayton
RSS265HF, #295-460 from PE.
The measured T/S spec's are:
Re-3.3 ohms,Fs-22.69Hz,Qms-3.02,Qes-0.47,Qts-0.40,Mms139.47,
Cms-0.35,Vas-1.9ft^3,Bl-11.87,Le-0.96Mh,Spl-87dB,Sd-51.42^2".
I was thinking of something like the "coffin" sub posted on the t-linespeakers.org website. That way, it could be a stereo sub and be used as furniture(wife would like). Thankyou in advance.
Sincerely,
Cambe
Old 7th December 2006, 09:34 AM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Maybe this 'Coffin' sized sub is too large for you?
Read post #190
http://www.diyaudio.com/forums/showt...39#post1075139
B
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 06:14 AM
LT1964-adj Help Needed or Part Needed lgreen Parts 2 29th June 2007 02:50 PM
PSU Help Needed ardo Power Supplies 4 26th June 2006 05:15 PM
Page generated in 0.06598 seconds (70.67% PHP - 29.33% MySQL) with 10 queries
