I've got a Massive Audio DMX15 in a sealed box.It is powered by a JBL BPX2200.1 amplifier.I would like to build a folded horn for this subwoofer.But I can't find a plan for a single sub design.
#2 |
And you likely won't. Horns are very difficult to design, and even harder to design well. What's more, horns for low frequency tend to be extremely large. Instead, I'd look into a Transmission Line configuration, or perhaps a "Daline".
#3 |
I second the TL option, with the modeling software done by Martin King they are almost trivial to design and build in comparason with a horn that would have the same extension.
One important question, what are your goals for this? |
#4 |
My goal at this point is to create a box that will pound your guts out.And,still be versatile enough to go in a daily driver.I have this subwoofer in a sealed box.Not a good choice of enclosures for this type of subwoofer.I do realise that going with a folded horn design makes things more difficult.But,I think the end justifies the means.
#5 |
Go and search Tom Danley. He designed the LabHorn. It goes really loud and is suitable for stadium use. The open air needs 12 boxes. Floor loading needs 6 boxes. Floor and wall loading needs 3 boxes. Corner loading needs just 1.5 boxes, but this can be achieved by one box and a mouth extender (really rigid and tightly sealed) pointing into the corner. An alternative is a pair of Labhorns stacked one above the other pointing into the corner. When correctly loaded the Labhorn extends down to about 27Hz and is absolutely unbeatable for loud music. Each labhorn is about 600L and uses two 300W 12inch drivers designed especially for this box. Use upto 1kW as an amp filtered steep (4pole) from 18Hz to 80Hz. This should give you ideas for designing your own box to mimic the extensive tech data in Tom's paper.
regards Andrew T. |
#6 |
Hallo
a bass horn for a 15" a horn must be very large, do you look: http://www.speakerplans.com/ a very small horn sub for the Peerless HDS 205 Nomex would be small and in living rooms with ~40 qm enough. http://www.hm-moreart.de/99.htm free download.
http://www.hm-moreart.de |
#7 |
If it's for your car then a vented box or bandpass will give you more output in a box that will fit. I doubt a labhorn would fit in your car.
Bill Fitzmaurice did an 'auto tuba' which is a small horn for cars. Thats the only one I know of. Cheers, Rob. edit: also take a look at the decware wicked one. |
#8 | |
http://www.carsound.com/forum/showth...2&goto=newpost I have this running in my car as we speak. It has amazing clarity, real weight, and serious "impact." I've been building horns for over ten years, and I'm willing to bet I'm one of a handful of people with a horn sub in their car today. A lot of people TALK about it sure, but no one actually DOES it. I agree that Danley is the sh1t, and that's why I have Unity horns in my dash. Fitzmaurice has some great designs too. :: PB :: |
#9 | |
If you really must build a basshorn,youl probably have to get some one to custom design it - or sell the driver you have,and build an existing design. Like the 1850 from speakerplans.
I did use a $10 8" on a 50hz corner horn in my hatchback.same woofer on 50hz ported box (~2.5cu ft) was 10dB quieter with same amplifier. When I butted the mouth up to the back window I did get a few dB more output,there was a massive null in the middle of the car when I turned the horn around to face the front. Interesting stuff. Definately loud enough for me.Maxed out my RS SPL meter with ~14w amplifier. Ive got a few pics someplace. |
#10 | |
| help with folded horn auto sub | americanaki | Subwoofers | 24 | 28th January 2009 02:27 AM |
| how to go from horn response to a folded bass horn design? | paulspencer | Subwoofers | 8 | 4th November 2005 10:44 PM |
| Folded Horn PA sub in car | eRiCdWoNg | Subwoofers | 7 | 19th October 2003 11:19 PM |
| Folded horn for Tannoy? | panos29 | Multi-Way | 12 | 17th October 2003 08:59 AM |
| Page generated in 0.12668 seconds (82.78% PHP - 17.22% MySQL) with 10 queries |
