Old 18th November 2006, 01:10 AM   #1
Default zobel
I'm trying to build a zobel circuit for a dual-coil 10" sub. The sub is 1.0mH and 4ohms, but is wired in parallel so the circuit sees 2 ohms. I don't know if I should us 2 ohms for the zobel calculation or use 4 ohms. With 2 ohms some pretty big cap values show up.
I would appreciate any help thanks.
Old 18th November 2006, 02:54 AM   #2
hooha is offline hooha  Canada
hooha's Avatar
When you say 4 Ohms you're referring to dual 4's right? So paralleling them will end in a nominal 2 Ohm impedance. You should go with the nominal impedance, which in this case would be 2 Ohms.
For a nice flat impedance, yes, it may take a large cap, but you may not have to go so big - the tweeter will pull the impedance down anyway.
Mark
Breaking speed records - http://www.mach5audio.com
Old 18th November 2006, 04:26 PM   #3
Yes this is correct. The final impedance is 2 ohms.
Please explain then how i incorporate the tweeters in the calculation to choose the right caps.
Old 18th November 2006, 05:03 PM   #4
hooha's Avatar
The proper way would be to do an impedance curve of the two units together to see just how much the woofer impedance is affected by the tweeter without impedance compensation.
Many times a zobel is not required, as an increase in impedance on the woofer may happen out of the woofer passband. This may be a desirable result as you would then have a natural decrease in output by the woofer at higher frequencies.
However, if the impedance increases too much within the passband, then a zobel of small parameters along with the added tweeter will tame the impedance of the woofer.
Mark
Old 19th November 2006, 04:44 AM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Shouldn't need a zobel for a sub woofer.
No longer DIY active
Zobel Or No Zobel ? sakis Solid State 74 2nd March 2012 09:32 AM
Do I need a Zobel ? chasingame Multi-Way 22 7th August 2009 11:45 AM
which cap do you like in zobel ? sandro600 Solid State 2 28th January 2007 10:36 AM
the zobel bigpanda Solid State 9 13th May 2006 03:56 PM
Page generated in 0.09124 seconds (74.87% PHP - 25.13% MySQL) with 10 queries
