Old 15th November 2006, 09:56 PM   #1
nate is offline nate  United States
Default Opinions please on my idea:
So here is the kit that I currently have and what I want to build.
I have a Adire 15" DVC Tempest sub and a high quality stereo 500 watt amplifier that is stable into a 2,4 or 8 load.
I would like to take advantage of the large x-max of the tempest and all of the power that I have to build a sealed Linkwitz transform sub.
My question is two fold.
1. Has anyone used the Marchand electric Bassis equalizer? http://www.marchandelec.com/wm8.html
I already have an appropriate power supply and other associate parts so I would only have to buy two boards with parts kits for $70ea and their nice cabinet for $60 for a total of $200. Any opinions on an alternative adjustable lilnkwitz transform/sub preamp option?
2. Since I have two good channels of amplification should I use a stereo signal from my main preamp and run each channel into a separate L/T preamp channel and then connect each channel of amplification into each voice coil? Each VC is 4 ohm, so I would have 500watts into each voice coil.
The constraints that I have are an electronics budget of $200 +/- $50 for the preamp.
I would appreciate any concerns or ideas that any of you have!!
cheers
Nate
Old 15th November 2006, 11:10 PM   #2
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
There is no need to run stereo channels into a DVC sub... Simply sum them before the LT and you will only need one channel of LT and EQ
The golden rule of DIY:
Build nice, or build twice!
Old 15th November 2006, 11:21 PM   #3
Thanks AwdyO,
I understand the that I don't need to run the vc separate. One channel of the amp will have enough power, I don't actually need two......
Do you have any other suggestions for preamp circuitry??
Nate
Old 15th November 2006, 11:31 PM   #4
BassAwdyO's Avatar
Well I'm not nessicarilly saying you should only use one channel of the amp. I'm just saying that the imput to the amplifier need not be stereo(two channels). You can use two channels of the amplifier if you like, but feed them both the same imput from a single LT/eq/preamp. You will probably be afforded a little more amplfier headroom this way and the extra power might come in handy as well.
This will save you money since you wont need two preamps with LT and EQ.
Old 16th November 2006, 01:54 AM   #5
thanks
What do you think? Your opinions. ashlar Car Audio 0 2nd December 2008 03:59 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
Your opinions please! davidlzimmer Multi-Way 10 18th May 2006 11:55 PM
Opinions on.... Sch3mat1c Solid State 9 26th November 2003 09:50 PM
Opinions please ... Simon Multi-Way 3 28th May 2002 09:12 PM
Page generated in 1.69102 seconds (6.62% PHP - 93.38% MySQL) with 10 queries
