Old 29th November 2006, 11:12 AM   #11
Pano is offline Pano  United States
Pano's Avatar
Hey Ed,
did you buy the Tang Band 8 inchers?
I have a buddy who loves those drivers. He uses them in a very small box with a tuning that is "all wrong" but raves about them. Lately he has been using them to supliment his open baffle Altec 605s and says they blend very well up to about 100dB.
Take the Speaker Voltage Test!
Old 1st December 2006, 02:41 PM   #12
theNoid is offline theNoid  United States
Send a message via Yahoo to theNoid
Paul, thanks for the positive comments. Mark, myself, and the few others that have heard it are very impressed with how it sounds. Nice and tight, not boomy, works great with the blues and classic rock that he listens to mostly.
Greg, we did not take an y measurements before or after to be honest with you. We basically looked around at the stuff we had for the project and built it, hoping for the best. Results were definately on the positive.
Motherone, thanks for the positive comments as well. As far as my impressions of it go, I would have to say impressive. I do believe it sounds as good as it looks for sure.
gychang, as far as an economic way of building it goes, I don;t think you can get any cheaper than we did. We used scrap plywood from other projects, the PVC was rescued from the trash-pile at a road construction site, the woofers themselves were donated by ApexJr.com as door prizes for the Florida DIY events I hosted and by trading, wheeling, and dealing, we managed to get Mark all four of them. The amp he is currently using was a buyout from MCM originally I believe and then I bought it even cheaper second hand. I'd say total, even if you had to buy the drivers, less than $200 total.
Cal, don't be fooled by the specs alone. These little buggers really can pump out the bass when called upon. As I have mentioned before, you throw four of them together, low-pass around 70Hz, a little bass-boost around 30Hz, and a small room...you get very well balanced, usable bass well into the 20's.
BassAwdyO, thanks for the comments, I would have to agree with you. It turned out better then I had originally thought once Mark started playing around with the suede and the stains.
Dave, I couldn't agree with you more man. How are you utilizing yours may I ask?
Ed, maybe a little late here but comparing them to the little Tang Band brutes I thik is a good match. Response-wise, pretty much a match in the same sealed enclosure. The TB's can handle a bit more power with their longer excursion but when you are using four of them, the super8's can literally shake the house when you decide it's needed.
breisch....thanks.
Sorry for the delay in my response here folks, and once again..thanks for all the positive comments.
Noidster
"Mmmmm......Beeeer"
Old 1st December 2006, 06:03 PM   #13
frugal-phile(tm)
planet10's Avatar
Originally posted by theNoid Dave, I couldn't agree with you more man. How are you utilizing yours may I ask?
No power so i can't get at the picture. A push-push pair in a BR box based on the small BR at Steve's site (built by SCD out of vintage scraps). Each driver has its own 50W (from an Aurex/Toshiba) power amp, This is directly driven by my Technics HT decoder/processor (so the woofer only works with movies). I have 1 channel of a proper XO breadboarded, but that job hasn't reappeared on the top of the queue yet.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st December 2006, 07:00 PM   #14
Speakerholic
Cal Weldon's Avatar
Noid, good to hear. I have held them in my hand and I can't see them making a driver like that for looks alone. I bet they make a fine woofer. I cringe when I hear them being called a sub though. I'm just old fashioned that's all.
The cabinet is work of art.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st December 2006, 07:16 PM   #15
Thanks again guys for the input here.
Noidster
"Mmmmm......Beeeer"
Filter caps from Apexjr. Stormrider Parts 0 8th February 2008 08:05 PM
Apexjr new transformer jaudio Power Supplies 23 19th June 2006 09:46 PM
ApexJr AlephX? tiroth Pass Labs 5 8th February 2004 12:58 AM
Buying from Apexjr - UK Paulr Swap Meet 4 26th June 2003 09:57 AM
ApexJr Alesis Amp Modules.. Ignite Solid State 3 13th January 2002 04:00 PM
Page generated in 0.08588 seconds (75.75% PHP - 24.25% MySQL) with 10 queries
