Hi everyone! Im in the process to build a ported enclosure. But when I was talking about braces with a car audio freak friend, he said that braces design is very important in order to not compromise SPL. What do you have to say about this? Do you think that bracing can compromise SPL in a certain way? I must add that I know that you have to put the end of a port or the back of the woofer enough far away from any boundaries (such as enclosure walls or justly, braces). My question is really just about how bracing an enclosure can affect the final performance.
Thank you!
#2 |
For one thing, the nature of resonances with a room/box/driver can change with SPL. A hum can turn into a buzz or a rattle, for example. Try it and see. Allow bracing to be added to a design later, perhaps with a panel that temporarily remains removable.
#3 |
Say you have a closed box. As the speaker is moving into the box it creates a pressure on the walls. These walls in turn want to move away from the box to counteract this force. If the speaker is moving outwards the cabinet, the walls try to move inwards.
The movement of the walls requires energy which is directly taken away from the speaker trying to convert it's movement into sound. Bracing is an effective way of making the panels stiffer and stiffer walls do intend to move less, taking away less energy. Bracing can be even more efficient than making the cabinet walls heavier/ thicker. In PA-speakers and caraudio drags the SPL is high enough to measure a significant difference, in Hifi the fidelity is in line (coloration of sound). So that's why everybody seems to be bracing. Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer. |
#4 | |
#5 |
Energy is transferred to the walls. It is stored and released. Some of this energy re-moves the speaker, some is converted to sound in the panels, and some is converted to heat.
The energy converted to heat is lost, but this not that significant with panels. More so with stuffing, as that is its job. Try for yourself though, lots of stuffing doesn't make a massive SPL difference, and some is necessary anyway. There was once (maybe still is) a notion amongst some in the car audio field that a resonant box helps you get loud. For the purpose of HiFi though, I disagree. As you said, it means distortion. Both in the frequency and time domains. At the end of the day, it depends what you are trying to achieve. Bearing in mind that there are some that like to make their cabinets a little like musical instruments with exotic timber that resonates musically. This aside, I believe it does not make much sense to build a cabinet whose panels resonate. |
#6 |
Speakerholic
If you are building a ported enclosure, the amount of bracing required is reduced as there is no or little pressure build up in the box. It is still a good idea to brace though and remember to offset the braces so they are not dead centre of any panel.
#7 |
I beg to differ. At 0Hz there can be no pressure build up. At critical frequencies though, the box resonance and driver wavefronts meet to create considerable pressure.
Regardless, panel resonance related to the dimensions is not about pressure build up. |
#8 | |
#9 |
I'm sure this has been covered numberous times in this forum before....
But to sum it all up 1.Bracing is important in subwoofers to increase panel stiffness so that the panels move less and hence offset the sound pressure created by the driver less. 2.Bracing in subwoofers need not be offset to create multiple panel resonances(we are out of the resonant frequency range of the panels) so a brace in the center will be the best 3. Ported boxes will have higher pressure inside of the enclosure near fb(which is why the driver excursion goes way down) However, Unless you are competing or demand overkill to satisfy your diy cravings 3/4" MDF really doesnt need a brace until the length exceeds 12-15"
The golden rule of DIY: Build nice, or build twice! |
#10 |
Interesting point here that I got with this famous friend tonight. Im gonna write this post too at the DIY audio forum.
When both of us talked about bracing and the effect on SPL, Ive got really great answers from you all. And really a big thanx for this by the way! I just talked at his place. I mean, everything I said was coming from his mouth. It seems like logical and beleivable. What do you think about all of this now? |
| Subwoofer enclosure internal bracing | rocko1290 | Subwoofers | 10 | 1st September 2006 03:04 PM |
| Does A Box Like This Need Bracing? | sdclc126 | Subwoofers | 10 | 12th May 2006 02:31 AM |
| Enough bracing? | Vikash | Multi-Way | 51 | 8th May 2006 06:58 PM |
| bracing of large cabinets and effects on internal reflections | JRKO | Multi-Way | 7 | 12th April 2005 08:12 PM |
| enough bracing?? | Chris8sirhC | Multi-Way | 3 | 31st January 2004 09:16 PM |
| Page generated in 0.13021 seconds (75.65% PHP - 24.35% MySQL) with 10 queries |
